ls1 master cylinder?
Old May 17, 2008 | 01:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
can I swap out my stock master cylinder for one from an ls1? I am looking for one a little more compact and I think the ls1' masters would work. I need more procharger clearance.
Old May 17, 2008 | 01:36 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: ls1 master cylinder?
If it bolts up, and it should, yo might need to change the pushrod on the booster as your stock one may be a hair too long. I have a similar problem using a master cylinder from a 2002 SS, I had brakes when I didn't want brakes and heated up the calipers pretty good. I'm still looking for a different pushrod, or I need to machine the stock one down.
Old May 17, 2008 | 01:42 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
all 93+ boosters and all 98+ masters are the same...v6 to v8...so don't pay extra for a "LS1 Master cylinder" and/or booster. I swapped in the entire booster and master from a 2000 Camaro V6 so that i didn't have problems with the pushrod. Threaded right in to the proportioning valve just like stock, just had to do a couple slight bends of the lines and it all went together nicely and looks great As far as using a 3rd gen booster, i didn't obviously so i can't comment on that end of it, although i believe as mentioned above it is possible.
Old May 17, 2008 | 09:02 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I am using my 82 booster with an 98+ master no problem.
Old May 18, 2008 | 03:16 AM
Firebat's Avatar
I'm using an LS1 master cylinder on my 92 v6 booster. The brakes seem like they are a little spongy but I think I just need to bleed it again really good.
Old May 19, 2008 | 06:34 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Stupid question here, but what is the easiest way to order the right one from, say, NAPA?
Exactly which model should I ask for?
Thanks!
Old May 19, 2008 | 07:03 PM
Firebat's Avatar
Just say you want a M.C. from a 98-02 firebird/camaro. They are all the same.
They are expensive new though. I've bought 2 used ones from LS1tech.com's classifieds for under $45 shipped each to my door and under 40,000 miles on both. I think a new one goes for around $160.
Old May 19, 2008 | 07:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
So 86+ camaros are a adirect swap for the ls1 master cylinder correct? I just want it since its more compact and my air cleaner can tuck by it better!
Old May 19, 2008 | 09:28 PM
Trick414's Avatar
Car: 1991 RS Vert
Thanks, here's one I grabbed off of napaonline.com:
http://www.napaonline.com/MasterPage...Cylinder+-+New
I think it will come in at about $125.
I notice that there is an electrical connector on the side of it. I assume you just leave that disconnected...
Thanks!
Old May 19, 2008 | 09:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Without seeing this connector, could it just be the low level sensor?
Old May 19, 2008 | 09:50 PM
Trick414's Avatar
Car: 1991 RS Vert
I'm sure it is. It is in the reservoir, so I can't believe it is anything like a pressure sensor. I would think leaving it unhooked is the way to go.
I need to replace my MC anyway, so I thought it would be nice to get a new reservoir as well without all the built up crud.
I just don't want to start throwing brake codes on the computer. I can't see how I would, but I wanted to make sure.
Old May 19, 2008 | 09:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you need to tweak the brake lines from the master to the prop valve a little
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
