Tube nut sizes
Old Jun 21, 2008 | 10:08 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Tube nut sizes
What is the size of the tube nut that does into the proportioning valve for the rear main line? I found the one on the end of the line is 6mm, 12mm x 1.0 bubble flare what is the one that goes into the prop valve?
Thanks.
Old Jun 24, 2008 | 09:46 AM
Car: 92' RS
Engine: LO3
Re: Tube nut sizes
For the sake of others who need the information and perform a serach here is the info:
Tube nut size at prop valve: 14mm x 1.50 Classic tube part number (ST8043)
at rear flex line connector: 12mm x 1.0 PN (ST8048)
z 28 jari
Sep 14, 2021 10:03 PM
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
Fox118
Sep 12, 2015 09:29 PM
m00n420
Sep 11, 2015 02:39 PM
