car not braking, but has fluid
Old Jun 21, 2008 | 04:10 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I have a 88 GTA with an automatic 305, & it has the 1LE brakes. A few days ago the brakes stoped working, the pedal goes in all the way to the floor & it barley stops the car. First thing I did was to check the fluid thinking I had a leak, but is all there. That makes me think that Im having problems with the master cylinder.
Can someone with more experience point me in the right direction. where should I start looking for problems & how?
Old Jun 21, 2008 | 05:15 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: car not braking, but has fluid
Was the fluid in the cilindar really low if so maybe you have an air bubble in the brake line id also look for cracks in the line by all the wheels.
also if you pump the breaks can u build up pressure?
Old Jun 21, 2008 | 06:53 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I havnt touched the system in more than 3 years, so I dont see why I would have air in the lines now. There is no leaks, I have stainless steel lines, & the fluid level is fine. & there is no pressure, even If I pump them.
Old Jun 22, 2008 | 02:43 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
sometimes the Master Cylinder can leak through the rear seal into the brake booster, where you can't see it. if there are no apparent leaks, i'd pull just the two bolts that hold the master cylinder to the booster and see if its wet in the back or not, if so, deffinately a problem, but a suspect none the less.
Terrell351
Jun 13, 2021 01:13 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
