Shaking when braking at speed
Old Jul 7, 2008 | 10:12 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Just found this out on a Camaro cruise...
My car shakes real bad, I think from the back, when I put the brakes on moderately hard and at higher speeds (70km/h or higher) (40mph?). Its not a warped drum or rotor feeling but rather a shaking feeling in the whole car (not the brake pedal). As soon as I take my foot off the brake it disapears. During normal gradual braking it is nice and smooth like new.
Any ideas?
Old Jul 7, 2008 | 10:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Shaking when braking at speed
sounds like a warped rotor/drum
if you are sure thats not the case check to see if the rear suspension, ie control arms and panhard are in good working order.
Old Jul 7, 2008 | 11:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds more like wheel hop to me.
Old Jul 8, 2008 | 06:54 PM
Dennis-Z28's Avatar
It felt like wheel hop to me too. Definately not warped brakes as I would be able to feel those at any speed braking and it was too violent to be that.
Old Jul 8, 2008 | 07:19 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
mine dose this to but i never thoguht anything of it
Old Jul 8, 2008 | 09:46 PM
scubasteve123's Avatar
Car: 1991 camaro rs
Transmission: 5 speed
Axle/Gears: stock for now
does the steering wheel shake real bad when braking and stop when you release the brakes? If it does than its definitely your brakes. If not I would lift your car and check for bent or broken suspension parts.
Old Jul 8, 2008 | 10:17 PM
dayton's Z's Avatar
Car: 85z-28
Engine: gm goodwrench 350
Transmission: t-5
Axle/Gears: stock, 3.08 one wheel peel!
not necessarily, ive had a few cars where you could only feel the warped rotor when applying the brakes at higher speeds 40mph+. changed rotors and everything went back to normal. and as stated before, check everything that holds the rear end in the car.
good luck
Old Feb 24, 2009 | 06:55 PM
rhit_rs's Avatar
Dennis, what fixed the problem? I just sent you a pm with the same question. Thanks!
Old Feb 24, 2009 | 10:19 PM
rhit_rs's Avatar
Old Feb 25, 2009 | 07:01 PM
Dennis-Z28's Avatar
New rear shocks, replaced all bushings with poly. Now its rock solid.
Old Mar 17, 2009 | 01:05 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Dennis...do you think the problem was primarily with the shocks or the bushings? I have driven a lot of junk cars earlier in life...and I found out that if shocks are bad...they can set up a harmonic resonance in the car similar to what you were talking about.
Or do you think that the worn bushings in the rear actually did cause minor wheel hop?
Just curious...
Old Mar 19, 2009 | 09:59 PM
Dennis-Z28's Avatar
Probably both but its just a guess. Maybe the extra play in the bushings let the back end jolt around a bit more and the shocks were so worn they could not damp that extra movement. The shocks were literally toast, I can compress them and they do not rebound even over time. DEAD
Old Mar 19, 2009 | 11:47 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
on my Buick it was doing this exact same thing horribly bad for a long time and then the Rack actually broke and now that its fixed it is 80-90% better. Soooo id say check all you tie rods, center link, and idler arm. They could be warn out and be causing the shaking. I know its weird but it fixed my car.
Old Mar 20, 2009 | 12:12 AM
Engine: LS3
Transmission: 6L80E
It is interesting how whether the car if FWD or RWD...there can be some troubleshooting similarities...including dead shocks/struts and worn bushings.
Old Mar 20, 2009 | 10:35 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Very odd i know, theres still a slite shake but i know thats bcuz it needs a set of rotors on it. Still the stock ones on it with tons of miles, the odometer dont work so yea.
Old Mar 29, 2009 | 07:22 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
Could be a Cracked drum? I just ran into this. Higher speed tend make my car shake with harder braking.
1992 Trans Am
May 10, 2023 07:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
