Weird Squeaking noise
Old Jul 30, 2008 | 04:40 AM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
My car is making a kind of squeaking/screeching noise when i drive down the road every once in a while. sometimes it does it for a long time and sometimes i barley hear it when i drive.it sounds like it is up in the front left tire. i also noticed that if i even barley touch the brake pedal the sound gos away everytime and it also makes the noise a little bit worse if i turn to the left.i had one guy say that the rotors are bad which doesn't really make alot of sense to me and another guy said to replace the brakes pads... any of you guys had this problem?what should i replace?thanks.
Old Jul 30, 2008 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Weird Squeaking noise
The pad is designed to make noise when replacement is required.
JamesC
Old Jul 30, 2008 | 05:21 PM
Jix01's Avatar
Engine: 305 5.0 TBI
really?never knew that. thanks alot!
Old Jul 31, 2008 | 10:38 PM
Jix01's Avatar
Engine: 305 5.0 TBI
if the pad made noise when it was supposed to be replaced wouldn't it make noise even more when i pressed on the brakes...? because it doesn't make any noise at all when the brakes are applied.
Old Aug 1, 2008 | 05:43 AM
Jix01's Avatar
Engine: 305 5.0 TBI
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
