Buying new calipers do i even need these things?????
Old Aug 4, 2008 | 02:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Im in the middle of restoring a posi disc rear and the calipers are shot, abused, rusted, and not worth the hastle, heres my question though, do i need those bracket like things that have like 6 1"X3" (or so) plates that are sandwiched together? They're held on by and 11/16 nut on each side, i cleaned em up anyway but im gonna attach a photo. Im not sure what they're for but they're obviously there for something lol
ALSO, since im getting a new set of calipers does anyone have the part #'s for the caliper recall kit?
Old Aug 4, 2008 | 04:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Buying new calipers do i even need these things?????
Those are the parking brake levers. Yes, you need them.
Old Aug 5, 2008 | 01:03 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
ah perfect then! i already cleaned em up with a rust inhibitor and im gonna spray them all later, already got the diff cover and bolts done too so now i just have the avle itself but im still chipping off old hardened grease and god knows what else off lol
one more question, the "bracket" you get when you buy the new set those wouldnt happen to be the same brackets that are held on by the torx screw would they? because today i stripped out that torx so bad its not even funny, the thing was so rusted it just turned to dust when i pulled on the wrench >_<
Old Aug 5, 2008 | 01:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't get a bracket when you buy new calipers.
Old Aug 5, 2008 | 01:24 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
i dunno it said "with bracket" so should i just clean up mine?
Old Aug 5, 2008 | 03:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
See what it comes with first, I guess.
Old Aug 12, 2008 | 09:54 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
I just put a posi rear end under my 85, the rear was from an 87. I am not happy at all with those calipers. I would upgrade to the PBR's. I am thinking of doing that now, after I have spent $150 on new calipers that I don't like, $70 on Hawks HP+ pads, and $160 on cross drilled and slotted rotors.
I know it is expensive to upgrade, but I am MAD at myself for not doing before spending all of this $.
If you stay with this style caliper, let me know if you are interested in rotors and pads with 500 miles on them. I love the pads and rotors, I am just sick of the calipers.
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
