Use compression fitting instead of double flaring?
Old Aug 28, 2008 | 09:04 AM
Firebat's Avatar
Can or should i use compression fittings instead of double-flares? I'm having problems getting a perfect double flare and running out of line because of many unsuccessful attempts.
Example: http://volksweb.relitech.com/brakeln.htm
Old Aug 28, 2008 | 10:44 AM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
Re: Use compression fitting instead of double flaring?
Brake lines have to be flared. Try practicing on a spare or old line and then when you get it right, do it on the car.
Old Aug 28, 2008 | 10:54 AM
Guest
Guest
Posts: n/a
Have any pictures of your failed flares? What flare are you trying to make anyway, was not clear from your previous post because you did mention a bubble flare. If its a double, I can offer some advice. It takes time, patience, and a little bit of tweaking the tools.
customblackbird
Aug 15, 2021 10:16 PM
gixxer92
Sep 1, 2015 04:32 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
Dialed_In
Aug 20, 2015 01:45 PM
