earl braided hoses worth it or not?
Old Aug 29, 2008 | 10:38 PM
luke84's Avatar
Car: 1984 z28
Engine: 355
just curious, i have read a lot of info in the searches that I have done on here. Some say yes upgrade, and others no because of failure. How many have really failed? Just looking to upgrade over stock but sounds like there are quite a few who are leary about these hoses. thanks for any input!
Old Aug 30, 2008 | 03:47 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: earl braided hoses worth it or not?
You must be thinking of the Russel lines. I havent heard anything bad about the Earls lines. I got them on my car.
Honestly, I wouldent upgrade unless your old ones are broke, or in real shabby shape.
Old Aug 31, 2008 | 04:33 PM
Firebat's Avatar
I got Earl's brake lines on both of my cars. I didn't notice any difference on my V6 that has stock brakes. They are better than the stock rubber hoses and if you are going to replace hoses, you might as well upgrade.
Old Aug 31, 2008 | 07:40 PM
mesterz2889's Avatar
if your stock ones arent already messes up go outside with some dykes and cut and never look back. i got em and i love em although i did have to trim em a little off the ends to make em fit but IMO well worth the $100
Old Aug 31, 2008 | 08:09 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Worth every penny.
Old Aug 31, 2008 | 09:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
definitely worth the investment. Its Russel's lines that seem to have issues
Old Sep 1, 2008 | 04:36 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I was wondering about that myself....
Old Sep 7, 2008 | 03:18 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I've tried them and didnt notice anything. I use rubber hose.
Old Sep 7, 2008 | 10:20 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
What is the difference ? You can't feel any difference in the brake pedal , braided lines wont make you car stop any quicker , braided lines do the same exact job as rubber lines without any performance gains !
The factory rubber lines are good for 100,000 + miles and are half the price , not to mention I can look at the rubber lines and get a good idea how they're holding up , braided lines get dirty and look the same until the day they die. ( I'm not saying they're going to fail I'm just bringing up the visual inspection aspect )
Old Sep 7, 2008 | 07:20 PM
Lo-tec's Avatar
yes you can
yes they will
look up for the answer to your question
and when they get old, they swell internally, and won't stop for nothing
please, tell me how the insides look when looking at them from the outside
been there, done that
x
Old Sep 26, 2008 | 02:30 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I wouldn't hesitate to get Earl's braided hoses. If you're going to do any upgrades to your brake system, you might as well use the best supporting components you can. Braided lines will increase braking performance!
Don't buy Russel's lines though, or else your pride and joy may end up looking like this:
If you're just keeping the car stock, feel free to replace the rubber hoses with new rubber hoses, they'll work fine too!
-Paul
Old Sep 26, 2008 | 02:56 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
www.anplumbing.com Best prices on the net for EARL'S
THE BEST place to buy EARL'S plumbing. Absolutely go with EARL'S. The failure most talk about is with Russell and XRP at times, etc. Most of the failures are usually do to improper assembly.
Go to www.anplumbing.com and "click to enter the shop" and then click the "tech videos". They are excellent "how to" videos. I am in the middle of my fuel line project. I have a mixture of Earl's, XRP and Aeromotive. I am finally taking step by step pics with part #'s and "how to". When completed I will post. Hopefully, it will help someone out.
anplumbing's customer service is excellent!
Old Sep 26, 2008 | 04:18 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
If your just talking about a street car, then replacing stock for stock is more than adequete.
When you drive something like mine, a dedicated road race type car, then you upgrade everything, including the brake hoses.
As pointed out already,
* yes, they do make a difference
* yes, you can feel the difference (with experience)
and yes they are necessary for this activity.
When you can consistantly hit 110 - 120mph down a front straightaway and must brake down to about 50mph to make that corner that someone stuck at the end of that loooong straight, lap after lap, all the equipment must be up for the task.
Mike
'87 Trans Am
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
