91 z-28 convertible-rear brakes
Old Sep 22, 2008 | 07:38 PM
fivefivem's Avatar
ok-i have a 1991 z-28 convert w/drum rear brakes. want to convert to disc. i have in my possession several 99 & 00 camaro z-28 rearend assemblies. can i use these brakes? do i need an adapter? i also have access to an 89 gta rear assy-would these brakes work better? any help greatly appreciated.
Old Sep 22, 2008 | 07:49 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: 91 z-28 convertible-rear brakes
https://www.thirdgen.org/ls1reardisc
Old Sep 22, 2008 | 07:58 PM
fivefivem's Avatar
i read this post but the conversion was not completed-does it work & what proportioning valve was used? also i think i read someone is producing adapters for the ls-1 brake converswion?
Old Sep 22, 2008 | 08:54 PM
alloy's Avatar
Car: 87 IROC-Z28
I don't understand what adapter you would need. You trim the housing, drill the holes out, and bolt everything on like in the article. No adapters needed. Then you will need a disk/disk prop valve. And you can even use the LS1 style hard lines with a little work to them. I've posted pics of how I did this, and pics of the brake lines I made up. The real work comes in setting the ebrake cables up.
Other than fabbing up the ebrake cables, it's a pretty straight forward swap.
https://www.thirdgen.org/forums/brak...-question.html
Old Sep 22, 2008 | 09:01 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Nope, no adpater needed on the rears. Just a bit of work fabbing up the cables for the e-brake.
OT: Hey Dan, how you doing over there?
Ed
Old Sep 22, 2008 | 09:11 PM
alloy's Avatar
Car: 87 IROC-Z28
Not bad Ed. Doing Ok really, just had my hand operated on this morning, hurts like h*ll. But they did give me some good drugs to take But I'm down for 10 days now. Puts a big crimp in my plans. But at least I got my T56 in before they cut me open. Been about 9 hours now since surgery and Im already going nuts sitting.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
