Rotor diameter in the recaro?
Old Sep 24, 2008 | 02:57 PM
bigmacnz's Avatar
Hello,
does anyone know the rotor diameter of the rear rotors on a 1982 recaro transam?
Old Sep 24, 2008 | 03:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rotor diameter in the recaro?
10 inches, the same as anything else.
Old Sep 24, 2008 | 03:09 PM
bigmacnz's Avatar
Thanks,
its just someone told me 10.5 inches like the GTA and i didnt want to order rotors the wrong size.
Thanks again.
Old Sep 24, 2008 | 03:10 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Originally Posted by bigmacnz
Thanks,
Thanks again.
It is 10.5 for both front & rears.
Old Sep 24, 2008 | 03:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It is 10.5 inches like the GTA and like every other model... there were no rear disc brake options, they're all the same.
Old Sep 24, 2008 | 03:17 PM
bigmacnz's Avatar
Thanks for that.
Old Sep 24, 2008 | 04:36 PM
DJP87Z28's Avatar
Then why did you quote 10" dia in your previous Post???
Old Sep 24, 2008 | 04:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Because it's just as commonly referred to as a 10" rotor since nobody needs to care what the exact size is since there are no other sizes available to distinguish it from.
Old Sep 24, 2008 | 05:34 PM
DJP87Z28's Avatar
So you are in the ballpark 10"+/- .5" . Sounds reasonable, however I would not let you do any measuring for me. Also the first time I heard someone say "commonly referred to as as a 10" rotor". What about 11.655 dia rotors???
Old Sep 24, 2008 | 06:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the 11.65 rotor is for the 1le optioned cars, it requires a different spindle and caliper. It will not replace yours.
Old Sep 24, 2008 | 07:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's called a 12" rotor.
Old Sep 24, 2008 | 07:31 PM
DJP87Z28's Avatar
That the rotor dia (11.655) for the 1989 later REAR brakes and noting do do with RPO 1LE option front.
Old Sep 24, 2008 | 07:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Since it wasn't available in 1982, it doesn't matter. In any given year there was only one rear disc brake package used, so you don't need to care what size they are.
Old Sep 25, 2008 | 07:08 AM
DJP87Z28's Avatar
Thanks for your amazing input. How I know thanks to you, I have 10" fronts & 12" rear Disc brakes.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
Briandrex
Oct 5, 2015 06:20 AM
the_hamturdler
Sep 30, 2015 12:50 PM
