using Vaccuum Guage to test Brake Booster...
Old Oct 9, 2008 | 05:49 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I've never used a vaccum guage before, but bought one this week. I want to test the Brake Booster. What numbers should I be able to see and do I need the engine running, brake system warm, or hook-up issues???
Is there any way to use a Vaccuum guage on the master cylinder?
The issue is having to shove peddle HARD to get very little braking. I got an all new 4-wheel disc setup from Ed Miller and it barely made much of a difference. The only parts that havn't been changed is the M/C & Booster.
Oh, I did notice that the power steering reseviour is seeping. Should I be looking at possible part upgrades for these 3 items or will Napa Auto/GM parts be the best available (we sure have ugly looking master cylinders!)
I'd appreciate your thoughts. Nitro-Nicky
Old Oct 9, 2008 | 10:05 AM
kcb37's Avatar
Re: using Vaccuum Guage to test Brake Booster...
You shouldn't be so much looking for a specific number so much as seeing if it will hold pressure.
But you will want somewhere around a min of 25.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
355sbcTPI
Aug 19, 2015 04:38 PM
