85 z brake problem
Old Oct 14, 2008 | 09:47 AM
dlbarton's Avatar
85 z brake problem
i have an 85 z28. when you push on the brakes they hold for a min then you here a sucking noise under the dash and the brakes fail. is this a vacuum leak?. and if so where does the vacuu line run under there. thanks
Old Oct 14, 2008 | 12:07 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: 85 z brake problem
sounds like your booster is leaking. no line under the dash, the noise should be coming from where the brake push rod goes into the booster.
Old Oct 16, 2008 | 07:54 AM
dlbarton's Avatar
thanks ill check that next
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
