E brake Too Short
Old Oct 21, 2008 | 09:51 AM
SpiderViper's Avatar
Car: 1987 Iroc-Z
Engine: 5.7L SB
Transmission: TKO 500
Axle/Gears: 10 bolt 373's and a Detroit Locker
E brake Too Short
Hey guys i did a swap in my 87 Iroc from the 9 bolt disc to the 10 bolt disc for the bigger ring gear. Everything went fine except for the ebrake cables they are too short!!! I don't know the year of the rear what can i do to make these work the rear brake cables are from my camaro and it was a firebird rear are they different i think the rear is an 88!!!
~Chris
Old Oct 21, 2008 | 12:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: E brake Too Short
If you went from a 9 bolt to a 10 bolt, you went down in ring gear size, not up.
Old Oct 21, 2008 | 12:43 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
Yeah I typed wrong sorry but can you help me with the question?
Old Oct 21, 2008 | 01:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Both rears have the same iron calipers?
Old Oct 21, 2008 | 03:33 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
There are 2 different designs of the ebrake cables. One has longer housing and shorter cable, the other has shorter housing and longer cable... Check NAPA's website and it will give you the exact measurements.
Old Oct 21, 2008 | 10:57 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Check what kind of calipers you have first, if you have PBR calipers you will need to go and order PBR ebrake cables from any 89 and up Camaro or firebird, the connector when the cable connects to the caliper is completly different. If you have iron calipers than your best bet is to go and ask for the e brake cables from a earler year, like 84.
Old Oct 22, 2008 | 11:07 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
Saber, yeah that sounds right the hook ups are different i believe they are PBR. Ill have to check put what you said I know they were aluminum caliber's an option i was told when you ordered the car.
Old Oct 23, 2008 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Cars weren't equipped with PBR's (11.7" rotors and single-piston alum calipers) until 89 when all rear disc brake cars had them). If the rear you're swapping in has rotors and calipers that are the same as your fronts, you have the old Delco-Moraine set-up, 82-88.
JamesC
Old Oct 23, 2008 | 01:06 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
I don't think they are the same i believe that the rear must be newer than 89 which would make sense now i just have to find a set of cables somewhere?
Old Oct 23, 2008 | 01:31 PM
JamesC's Avatar
Check to see if the new rear end is the same length as the old. If it's longer by some four inches, you have a fourthgen rear. The LT1, 93-97, had PRB's (which are nearly identical to the thirdgen version); The LS1 calipers, 98 up, were quite different. If the rear is the same length as the old with iron calipers it's 82-88, with PBR's 89-92.
JamesC
Old Oct 23, 2008 | 03:28 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
I've never seen an '84 with rear disc...
Old Oct 29, 2008 | 09:48 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
Nope it is the same size... THe hook ups are diffrent and they are not the same as the front so it looks lioke im giving PBR a call.
~Chris
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
Bryan F
Aug 27, 2015 07:28 AM
