Ebrake cables converting to PBR rears
Old Jan 10, 2009 | 10:11 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I'm looking into converting my rear iron calipers to PBRs. Is it just as simple as changing out the two cables to the calipers, or do I need a new equalizer assembly?
Old Jan 11, 2009 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Ebrake cables converting to PBR rears
Originally Posted by trumps2000
I'm looking into converting my rear iron calipers to PBRs. Is it just as simple as changing out the two cables to the calipers...?
Yes. But a reconsider. I'm not sure I answered the full extent of your question. Note the link that I've posted below for a blow-by-blow description of the swap.
JamesC
Old Jan 11, 2009 | 10:47 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
do they make pbr brakes the 1983 pontiac trans am. When i went on their site it was not there
Old Jan 11, 2009 | 10:56 AM
JamesC's Avatar
Whose site?
IIRC, 82-83 have SAE fittings, so that might be of some concern (but I have no experience with them). Here's the how-to:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Jan 11, 2009 | 08:16 PM
trumps2000's Avatar
Car: 1985 Z28
As usual ur the man James thanks! Nice write up too, just wasn't sure if I was missing something. When you swapped were the backing plates still available from GM?
Old Jan 11, 2009 | 08:55 PM
JamesC's Avatar
Yes.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
