How do you remove axel shafts?
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I'm upgrading the brakes on an 84Z and need to get the backing plates off. I've done searches but can't find any that walk you thru removing the axel shafts so I can remove the plates. Thanks.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: How do you remove axel shafts?
Remove differential cover,turn carrier until bolt for
spider pin is exposed(5/16 head as i remember),take
out bolt(might not be able to remove completely)
pull out spider pin,push in axle,c-clip should fall out
axle can then be pulled out.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
dbrochard
Oct 3, 2015 12:43 PM
