PowerMaster conversion?
Old Feb 24, 2009 | 09:27 PM
Tice's Avatar
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
I've been considering a PowerMaster (Power Master) conversion of sorts... Is it a simple step by step process like I hope?
Step 1-remove Vacuum assist unit entirely
Step 2-Bolt in PowerMaster...
I know the Rod from the pedal to the master will have to be shorter... and I'll have to get a Stockpile of Accumulators, as they go bad at least once every 3 years, or so...
Is this a dumb idea? I mean, it'll save weight, open the engine bay, and still work incredibly well... Shoot, the Grand Nationals had them... Why can't we?
Old Feb 25, 2009 | 08:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: PowerMaster conversion?
To tell the truth I wouldn't put a PowerMater on any car. They are just too unreliable. Many of the GN owners remove them in favor of vacuum assisted, manual, or hydraboost systems.
Also check what is required for wiring. There are wiring diagrams over on gnttype.org
RBob.
Old Feb 25, 2009 | 08:30 AM
Tice's Avatar
Really? I've heard that PowerMasters were Super reliable and Favorable. I've heard of Guys swapping Vacuum and Hydros out for them in older rods, and Even newer cars, like the Shelbys...
In any case, I think I'd like the reduced clutter... All You have to do to maintain them is Swap the accumulator every so often, or make sure the Switch isn't stuck... And bleed the system,nothing too Labourous, or hard to maintain. Not a whole lot can go wrong.
Thanks for the link, I'll check it out.
Old Feb 25, 2009 | 07:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Seriously, I would not have posted what I did if I did not have good reason. Check some of the Turbo Buick boards about the '86 & '87 GN's and GNX's that have or had a PowerMaster system.
In '89 GM went back to the vacuum booster for the TTA's.
RBob.
Old Feb 25, 2009 | 07:46 PM
Tice's Avatar
Guess I'll stick with the Cluttered Engine Bay... Thnx RBob
Old Feb 26, 2009 | 07:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you don't mind some pressure lines HydraBoost is another way to go. It runs from the P/S pump, hence the need for the high pressure lines. It is a compact unit.
RBob.
Old Feb 26, 2009 | 08:08 PM
Tice's Avatar
any idea how tough it would be to swap? Thanks in advance
Old Feb 26, 2009 | 09:14 PM
Suaveat69's Avatar
Could try one of these. Electric with adjustable pedal.
http://www.abspowerbrake.com/electrichppage.html
Old Feb 27, 2009 | 08:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here are some threads with pictures. Note that the install-pictures thread has had the pic's moved to photobucket. There is a link to them in that thread.
https://www.thirdgen.org/forums/brak...dra-boost.html
https://www.thirdgen.org/forums/brak...ydraboost.html
https://www.thirdgen.org/forums/brak...-pictures.html
Rbob.
Old Mar 5, 2009 | 09:44 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
I have an 1987 GN... with a toasted powermaster in it. I do plan on putting another one if though seeing as the car is 100% stock down to the orginal window sticker
The units usually fail due to lack of maintence... require annual flushing of the brakes... and should probably run DOT 5 Silicone instead of cummy DOT3
Old Mar 6, 2009 | 12:05 PM
Tice's Avatar
True that. Ok. I guess if I decide to redo the brakes (Car could use it... Probably never seen brake job in it's 18 yr life...) I'll swap to the Hydroboost, like the vettes have. Thanks guys.
On that note, is there anything I (A novice) should know about a Hydroboost swap real quick? I mean, I'll research before I do the swap, but, are there any secrets?
Old Mar 6, 2009 | 02:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The only item that seems to be an issue is the return line plumbing. The return from the HB unit and the return from the P/S box should enter separate from each into the reservoir.
Some setups have them T'd together, which can cause the HB unit to slightly apply the brakes (they drag a little).
If you can check out an Astro van setup. Has a remote reservoir high on the cowl.
It also sounds like you have a stock brake setup. Should look into upgrading to some larger front rotors and PBR calipers. Even the C4 12" setup is worlds above the stock 10.5" single piston iron caliper brakes.
RBob.
Old Mar 7, 2009 | 10:12 AM
Tice's Avatar
You bet, I've already bought 12" Rotors (Dimpled and Slotted, for what it's worth) from R1Concepts.com, I'm Saving up for new Calipers. (can get pricey...)... Thanks for all the help RBob
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
