Upgrading pads?
Old Feb 25, 2009 | 07:17 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
Upgrading pads?
I have the stock braking on my 89 Iroc with disc front and rear. Can I find some better pads than the usual cheap ones? If possible something that will not eat my discs in 3000miles.
Old Feb 26, 2009 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Upgrading pads?
You might consider Hawk brake pads.
JamesC
Old Feb 26, 2009 | 11:00 AM
loopingz's Avatar
Re: Upgrading pads?
They seem to do the job.
Are the pads the same front and rear? (Camaro IROC Z 89, with rear disc and not 1LE edition).
http://cgi.ebay.com/ebaymotors/Hawk-...Q5fAccessories
Old Feb 26, 2009 | 11:10 AM
JamesC's Avatar
Re: Upgrading pads?
No, the fronts are the common Delco-Moraine iron calipers found on the fronts of all 82-92 thirdgens (except the 1LE, of course). An 89 equipped with rear discs should have PBR alum calipers.
http://www.spohn.net/shop/1982-1992-...es/Brake-Pads/
JamesC
Old Feb 26, 2009 | 11:21 AM
loopingz's Avatar
Re: Upgrading pads?
I am not a 1LE models but I do have a 9 bolts borg wagner. Are the brakes differents?
Old Feb 26, 2009 | 12:09 PM
JamesC's Avatar
Re: Upgrading pads?
No, the calipers are the same. If you have an 89 9-bolt, you should have PBR's, IIRC. Recheck the link above. I screwed the pouch the first time.
JamesC
Old Feb 26, 2009 | 01:39 PM
loopingz's Avatar
Re: Upgrading pads?
Thanks the corrected link is working great. I think I will try that.
Old Feb 27, 2009 | 03:58 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Upgrading pads?
I have the older rear calipers (83 car). The same Hawk HPS pads fit both front and rear. They stop ok, but I am looking forward to upgrading (replacing) the brakes.
Old Mar 3, 2009 | 07:13 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Upgrading pads?
I am running HP+ front pads and HPS rear pads and the car stops amazingly well considering I don't even have the PBR brakes. However, I wouldn't recommend the HP+ pads for a street vehicle... way to much brake dust.
I actually have another unused set of HP+ front pads and HPS rear pads that I have never used that I am thinking of selling. I took them out of the packaging but they never even touched a rotor or caliper. I had them as a spare set incase the pads cracked when I was autocrossing, but I won't need them anymore becasue I'm upgrading to LS1 brakes. I'll try and find where I put them and the exact part numbers.
Old Mar 4, 2009 | 07:25 AM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
Re: Upgrading pads?
those pads you have will they fit an 84 rear brake set up as well as a 86 front setup? also what do you want for them?
Old Mar 4, 2009 | 10:28 AM
loopingz's Avatar
Re: Upgrading pads?
Are you confident the brakes are the same for the 9 bolt.
Because here is an extract from the spohn description:
Note: Will only fit 10 Bolt Rears on 1989-1992 F-Body equipped with PBR aluminum caliper rear disc brakes.
I know my calipers are aluminum, but I want to be sure with a warning like this.
Old Mar 4, 2009 | 11:00 AM
JamesC's Avatar
Re: Upgrading pads?
PBR's, regardless of rear ends or years, are exactly the same. Spohn's description should read: Fits 89-92 F-Bodies equipped with PBR alum caliper rear disc brakes.
As an FYI, the only difference between the 9- and 10-bolt with PBR calipers/rotors is the backing plate. All else is the same.
JamesC
Old Mar 4, 2009 | 07:22 PM
Car: 1987 IROC-Z
Transmission: TH350
Re: Upgrading pads?
Ok, the part number for my...
Front pads (HP+): HB119N594
Rear pads (HPS): HB119F594
Click the part number to go to their description on TireRack.
Mike
Vintageracer
Sep 24, 2017 12:34 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
loud91rs
Oct 5, 2015 10:05 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
