Which parking brake cables?
Old Mar 8, 2009 | 08:06 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
I have a 86 Z28 I'm putting a 95 LT1 differential in. Would the parking brake cables for a 90-92 with disc brakes work better then the cables from the 95?
Old Mar 8, 2009 | 08:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Which parking brake cables?
Check down a bit in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 8, 2009 | 09:38 PM
Car: 86 Z28
okay so I'll buy the cables for the 90-92 with 4 wheel discs.
Old Mar 9, 2009 | 01:47 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Not for your '86, the '90-92 cables are for the cars with no adjustment in the trans tunnel. You need "first design" cables for the '88-early '90 cars.
Ed
Old Mar 9, 2009 | 08:21 AM
JamesC's Avatar
Ed, Rockauto shows the first design (1434 mm) available in 90, 91, and 92. Which makes sense, I guess, because of this from Duck: Yes, the "long adjusting bolt" version shown in the [Ed's] photo is the same as the '92 Z28 with disk brakes.
RockAuto shows the second design (1460 mm) in 91 and 92.
I've always 'assumed' that these were correct. At any rate, I used the first design in a PBR conversion into my 85, which has the tunnel adjustment, and all went well. The longer second design would have been used for cars unequipped with the tunnel adjustment, correct?
JamesC
Old Mar 9, 2009 | 04:50 PM
Car: 86 Z28
I had looked on rock auto and it showed the first design, which is what I heard before to get. Will the cables be routed the same as the cables for the drums on my car right now? will they reach the calipers okay since the 4th gen rear is a little wider?
Old Mar 10, 2009 | 04:13 AM
ebmiller88's Avatar
JamesC
From what I have learned/experienced, yes.
Ed
Old Mar 10, 2009 | 04:14 AM
ebmiller88's Avatar
They will route the same as on your car. Over the rear axle, then around and under to the cable bracket. Connect to the calieper bracket first, then to the cable in the tunnel and adjust.
Ed
Old Mar 10, 2009 | 09:22 PM
Car: 86 Z28
Cool, Thanks!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
