Earl's SS Brake Lines
Old Mar 16, 2009 | 07:10 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Can any one tell me what the difference is between these two? I am changing my rear brakes from drum to PBR rear disk in my 91 bird.
http://www.spohn.net/shop/1982-1992-...sc-Brakes.html
Old Mar 16, 2009 | 07:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Earl's SS Brake Lines
If you have OE front discs and you're installing PBR's (often called 1LE, but all disc brake cars, 89-92, are equipped with them), you'll need the kit in the first link. If you've installed 1LE fronts and are swapping in PBR's in the rear, you'd need the kit in the second link.
JamesC
Old Mar 16, 2009 | 10:45 AM
91banditt2's Avatar
Engine: 5.7 HSR
i have the factor iron front brakes but will be upgrading to a yet to be determined set in front. so will i be ok with the 1LE lines for the time being?
Old Mar 16, 2009 | 12:22 PM
JamesC's Avatar
I have no experience with any larger than the 1LE's. I 'asssume' they will fit larger applications. A PM to Ed Miller or search might be find more significant info than my assumption.
JamesC
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
