Leaking Brake Fluid
Old Apr 17, 2009 | 04:05 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Leaking Brake Fluid
I am leaking fluid from my prop valve is it time to get a new one or is the master cylinder what is bad. Sorry if I sound stupid I don't know much about brakes and I have searched for the last couple days and can not find what i am looking for. any advice I don't feel safe driving the care with it leaking brake fluid.
Dan
Old Apr 17, 2009 | 04:30 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Leaking Brake Fluid
Where exactly is it leaking from? Pics would help alot. Your master cylinder is probably alright, as long as the brake fluid you're seeing isn't running down the lines from the master cylinder and dripping off the prop valve. Is it leaking from the fittings, or somewhere else?
Old Apr 19, 2009 | 03:13 AM
DanTeix's Avatar
Engine: 305 TBI
Ok the proportioning valve is bad where do i buy a new or rebuilt one at a good price?
Dan
Old Apr 19, 2009 | 09:50 AM
Pocket's Avatar
Car: 91 Trans Am
Parts store sells cast iron remans
JY sells originals very cheap
Old Apr 19, 2009 | 03:25 PM
DanTeix's Avatar
Engine: 305 TBI
Sorry but what is JY? Oh junk Yards ok well you think getting a JY one would be a good place holder till I can get a new one.
Sorry about the double sig post I always forget to unclick it.
Old Apr 19, 2009 | 08:15 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Junkyard one should be fine. Proportioning valves very rarely go bad. Are you sure its the valve itself and not the lines? It's not leaking around the threads is it? Just want to make sure you avoid as many headaches as possible.
Old Apr 20, 2009 | 01:54 AM
DanTeix's Avatar
Engine: 305 TBI
No its leaking from the valve itself right wear that rubber cap is
Old Apr 20, 2009 | 07:57 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Oh ok. I didn't see where/if you mentioned where the leak actually was coming from. In that case, I'd just hit the local junkyard and grab one.
jklein337
Sep 19, 2018 06:23 PM
LittleFranks
Sep 17, 2015 12:22 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
