Caliper Issues..... Again
Old Apr 26, 2009 | 11:22 AM
JustinTR's Avatar
Okay so when I first got the car, about 3 months into driving it, the caliper just kind of... froze. Smoke everywhere. It was the same day that I got my pads replaced. so I had to get the car towed. I replaced the caliper, and it was fine.
So yesterday, im on my lunch break and it starts pulling to the left. I could kind of feel it doing the same thing. I managed to get back to work, but it was still hot and it was smoking. SO an hour after that when i left work, I was expecting to just barely make it home without it smoking like crazy (i live about 10 minutes from work).
But when I started driving, the issue seemed to have resolved itself. Now thats what I had thought until i had to stop. Pedal goes all the way down to the floor and I barely have enough to stop at the sign. I bled the lines today and it fixed the problem JUST enough to where I feel like I can drive it safely. This is the same side that was replaced about 2 years ago.
The car has always pulled a little to the right when you slam the breaks, but the right caliper may just have a little more grab.
This all happened right after I finally got myself detached from this car and I was going to sell it. Yeah. Im pretty sure it knows what im thinking and its just trying to **** me off now.
Old Apr 27, 2009 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Caliper Issues..... Again
The symptoms you describe would seem to indicate the rubber brake hoses acting as check valves.
JamesC
Old Apr 27, 2009 | 05:15 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
had it happen to me . with age they collapse internally , can act as check valves both ways . good idea to replace them all , they are keyed to lt. & rt. so be sure to install on correct location . good luck .
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
