Bolt in Adjustable Proportioning Valve
Old May 4, 2009 | 01:40 AM
JERRYWHO's Avatar
I will not cut all the brake lines to install a adjustable proportioning valve with a rear pressure gauge, so this is my way to save the brake lines, front metering valve and switch.
What do you think.
Jerry
Attached Thumbnails Bolt in Adjustable Proportioning Valve-mvc-004f.jpg   Bolt in Adjustable Proportioning Valve-mvc-006f.jpg
Old May 4, 2009 | 02:03 AM
Stephen's Avatar
Car: 87 GTA
Re: Bolt in Adjustable Proportioning Valve
Care to explain the plumbing....How it works, etc?
Old May 4, 2009 | 06:19 PM
JERRYWHO's Avatar
If you look at the picture with the pens. The top pen is the port from the master cylinder and you can see the flow will be to the outside of the tube in the factory valve and go into the new aluminum body and out the number 4 stainless line to the inlet of the SSBC adjustable valve and then down the center of the o-ringed tube to the factory valves outlet. (the lower pen.)
The pressure gauge is tapped in on the downstream side of the new adjustable valve to see the rear brake pressure.
Jerry
Attached Thumbnails Bolt in Adjustable Proportioning Valve-mvc-006f.jpg   Bolt in Adjustable Proportioning Valve-mvc-004f.jpg
Old May 4, 2009 | 06:29 PM
Stephen's Avatar
Car: 87 GTA
Not sure if I understand it, since the external goes of of the adjuster & back into the adjuster, but only 1 inlet/outlet to the adjuster.
Is this something you have considered selling to others?
Frozer!!!
Jan 19, 2024 04:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
