Hey Ed!
Old Nov 1, 2006 | 12:22 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Hey Ed!
How is the LS1 rear brake cable set-up coming along? I so want to get started on mine....
Old Nov 2, 2006 | 02:15 PM
'Shifter's Avatar
Car: 87 Z-28
Old Nov 2, 2006 | 07:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey there...no progress on the cable this week, I hope to move the car onto the carport and take the final measurements this weekend and get the cables moving on Monday or Tuesday.
FYI to others interseted, I'm having true bolt on LS1 conversion cables made so there will be no modifications needed to get them to install correctly, work well and work right. The first cables will be specifically for the earlier, pre-'90 cars like Mark's that have e-brake cable adjustment in the trans tunnel. I'll do another set for the later '90-92 cars when I can, hopefully not too long after these are made.
Ed
Old Nov 3, 2006 | 10:22 AM
'Shifter's Avatar
Car: 87 Z-28
Ed
Old Nov 9, 2006 | 01:53 PM
ebmiller88's Avatar
As an update on these bolt in conversion cables, I just got off the phone with the manufacturer of the cables and will be sending my test pair to them tomorrow and hope to have the new cables back soon.
Mark, want to be a guinea pig for the first set?
Ed
Old Nov 9, 2006 | 02:37 PM
'Shifter's Avatar
Car: 87 Z-28
Hell yeah! How much are they gonna run?
Old Nov 9, 2006 | 03:46 PM
ebmiller88's Avatar
I don't know yet but they should keep in line with a replacement set. If my dimentions are right and they work as I hope they will, I'll have 10-15 sets made and this will lower the overall cost. I hope they will come in the $25-30 each range but the ease of install benefit will be worth it I'm sure.
Ed
Old Nov 9, 2006 | 04:28 PM
'Shifter's Avatar
Car: 87 Z-28
I sent you a PM Ed!
Old Nov 9, 2006 | 10:38 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
Count me in for a pair too!!
Old Nov 9, 2006 | 11:33 PM
ebmiller88's Avatar
Will do..while we're at it, who else would be interested in a set of true bolt in LS1 rear disc conversion e-brake cables?
Ed
Old Nov 10, 2006 | 11:11 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I need a price for front LS1 stuff Ed so you can more than likely count me in too. just pm me thx
Old Nov 10, 2006 | 11:36 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Ed, i would definitely be interested in a set of those cables for the late '80s set-up(adjuster in tranny tunnel)
when do you think they will be available?
Old Nov 10, 2006 | 12:48 PM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
This is just a reminder not to forget about me.
I'm still in I PM'd you months ago and you told me you'ld get back to me when there ready. Question: I have a 1990 Camaro and at first I had the ebrake adjuster in the tunnel, but about a year and a half ago I had my rearend changed out with an 87 iroc. Well right now as I write my rearend is at Hooper's(California Rearend Specialist) getting a complete rebuild. With that said when I got under the car to remove the cables from the adjuster to get the rear off I noticed I no longer have the adjuster. What do you think happened? I also remember not having tension when I pull the ebrake lever and told myself(prior to knowing I have no adjuster) that one of these days I'd get under there and tighten the cable. I really never use it, but I'd like to know I have it when I need it.
Old Nov 10, 2006 | 07:42 PM
ebmiller88's Avatar
Yes I did and I will get with you as I said I would, Mark also got with me months ago on this request. These cables have been on my to-do list for about a year but as with other things my schedule got pushed a little and I'm finally getting to them. I'm trying my best fellas and I'll get with you all when the cables are a go.
I was going to ask you about your adjuster assembly, funny you should mention it. I know that '90 is the swapover year on the adjustment in the trans tunnel...so you are saying that you don't have the long adjuster bolt on the park lever cable? You should just have a piece of steel that the cables attach to, right? If that is so, then '90 is right and you don't have the provision for adjustment under there, the cables need to be one length and that's why I will also have to make a second design to fit cars such as yours. Are you able to take any measurements under there without a big inconvenience?
Ed
Hopefully the cables will be done in a week, then allow a week to verify I got them right, then we're a go. I'll place an order for 10-15 pair depending on demand.
PM sent.
Ed
Last edited by ebmiller88; Nov 10, 2006 at 07:44 PM. Reason: Automerged Doublepost
Old Nov 10, 2006 | 09:17 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
really? Count me in for a set for my 91 when you get em made for that model!
Old Nov 10, 2006 | 11:24 PM
87zjeff's Avatar
Ed, definitely want them. i just bought my LS1 rear this week so these would be really great.
Old Nov 11, 2006 | 09:48 AM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Count me in for a set too! With winter coming, I may just need them.
Old Nov 12, 2006 | 01:12 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Ed, im down for a set of the cables too. My car is an 89 so i have the adjustor. Could you PM me once they r all set so i could send you the money for em.
matt
Old Nov 14, 2006 | 10:02 AM
black88iroc45's Avatar
Car: 88 iroc
Engine: 355 tpi
Transmission: 700
Ed Count me in for a set thanks
Old Nov 15, 2006 | 10:37 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Any advantage of the LS1 rear setup over a 12" PBR stock type setup? May want to get the cables if I decide to do something different for the rear.
Old Nov 17, 2006 | 07:27 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
LS1 e-brake cables
Put me down for a pair. My car is a '88. thanks Ed.
Old Nov 17, 2006 | 05:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hey ed, just got brake lines from you, i could use a set of those fancy custom cables too, they would probably make my life a little easier. let me know when you get them made
Old Nov 17, 2006 | 06:25 PM
ebmiller88's Avatar
Will do, your lines are shipping tomorrow. I'm making a list of guys who need cables and will post it when they're done.
Thanks!
Ed
Old Nov 17, 2006 | 06:49 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I need ebrake ls1 cables for an 86.
Old Nov 24, 2006 | 05:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
so Ed, any news on cables?
Old Nov 24, 2006 | 07:47 PM
ebmiller88's Avatar
Vendor was closed for the holiday weekend, I'll check on Monday.
Ed
Old Dec 4, 2006 | 09:19 PM
ebmiller88's Avatar
I checked with them on Friday and they told me they were finalizing my quote....whatever that means. I'll let you guys know when I know.
Ed
Old Dec 9, 2006 | 12:53 PM
'Shifter's Avatar
Car: 87 Z-28
Ed
Old Dec 9, 2006 | 03:37 PM
ebmiller88's Avatar
I got a message from them on Friday (12-8) that they had my quote ready but I was busy with other things..I'll call them on Monday to finalize it. At least they have them ready to go. I'll get them to Mark as soon as I can. When they arrive I'll post up a new thread with pics and ask you guys to verify if you want a set, I think we've got quite a few of you interested.
Ed
Old Dec 9, 2006 | 03:50 PM
'Shifter's Avatar
Car: 87 Z-28
Ed
Very cool Ed, I'm chompin' at the bit!
Old Dec 9, 2006 | 05:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
sweet !! cant wait, ill take 1
Old Dec 9, 2006 | 09:58 PM
87zjeff's Avatar
it would be so cool to have these when i insall my rear end.
Old Dec 12, 2006 | 09:00 AM
ebmiller88's Avatar
Well $%*(#(&*&^#%@# !!!!!!!!!!!!!
Just got off the phone with the vendor and they can't make them. Their parts won't work with what we need and they don't have anything close to what is on the GM cables. Looks like we'll have to go another route. Their website specifically states that they "can make custom cables for any application." and I just proved that wrong.
BUT.....I have already found another vendor and will be calling them in a minute to get the ball rolling again but now it looks like the cables won't be ready until the new year. Again, I'll keep you posted.
Ed
Old Dec 12, 2006 | 01:13 PM
'Shifter's Avatar
Car: 87 Z-28
Ed
Old Dec 12, 2006 | 06:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
aww poo, i was getting all excited there for a bit, was getting ready to start the conversion. looks like it gets put off a little further. oh well its cold here and id rather do it when its warm anyway..
keep us up to date ed!
Old Dec 12, 2006 | 10:44 PM
ebmiller88's Avatar
Cables are at the new vendor already.
Ed
Old Dec 12, 2006 | 10:58 PM
87zjeff's Avatar
Old Dec 15, 2006 | 06:08 PM
'Shifter's Avatar
Car: 87 Z-28
Ed
Old Dec 18, 2006 | 11:56 PM
anthony714's Avatar
when can i get a set.im tired of using a brick to stop my car form rolling plus it doesnt look good with the ladies when i have to run out and remove a brick
Old Dec 19, 2006 | 07:27 PM
ebmiller88's Avatar
Hopefully not too long, we'll see what the new vendor has to say. I'll put you on the list and they should be done close to the new year.
I know this delay in getting the cables finished is probably longer than a lot of you would like but such is the case in custom parts. I assure you all I'll get them in the market just as soon as I can and you'll be very happy with them.
Ed
Old Dec 19, 2006 | 08:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i got my fingers crossed.
thanks for doing this ed,
Old Dec 21, 2006 | 02:34 PM
  #42
anthony714's Avatar
eb if you pull this off ill let you have my wife for a night,heck if you pull this off ill make it a week.maybe i can get some sleep that way
Old Dec 21, 2006 | 04:26 PM
  #43
ebmiller88's Avatar
Now THAT'S motivation! Got pics?
Ed
Old Dec 21, 2006 | 05:43 PM
  #44
87zjeff's Avatar
Old Dec 21, 2006 | 06:19 PM
  #45
anthony714's Avatar
you must stop and ask yourself 2 questions,1-how babd does he really want these cables to give up his wife? or 2-how bad can she be that hes so willing to give her up for a lousy e brake cable?
Old Dec 21, 2006 | 10:49 PM
  #46
87zjeff's Avatar
that's why he wants pics first
Old Dec 28, 2006 | 06:58 PM
  #47
//<86TA>\\'s Avatar
Car: 86 Trans Am
almost finished with my ls1 swap... waiting on e-brake cables...about to rig something that may be hazardous to my health and of others...any new news ed? please...for the sake of others...
Old Dec 29, 2006 | 01:29 PM
  #48
ebmiller88's Avatar
No news yet, I'll check in with them.
Ed
Old Jan 2, 2007 | 09:21 AM
  #49
Firefighter's Avatar
Car: Trans Am
Engine: 355 TBI
Transmission: Automatic
Axle/Gears: 9 Bolt 3:27 Gear
Hi Ed,
I 'm also intrested in the Cables (89 Car). So put me on the List for a pair!!!!!
Wrote to you a few Days ago by PM.
Old Jan 6, 2007 | 03:28 PM
  #50
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
i'm installing a moser 9 inch in my 92 RS with a disc brake set up from a 2002 Z28. are these e-brake cables and brake hoses what i will need?
