is my brake booster shot?
Old May 14, 2009 | 07:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Been having an issue.
Last fall i noticed that my brakes were not working well, i would push the pedal, it would travel about an inch and a half then become hard.
I added an extra vacuum canister and its better, but not what it should be.
Is my booster bad? its stock. The engine make just enough vacuum that the brakes should not be affected
a 4th gen booster will bolt in place of my stocker right?
thanks
-Phil
Old May 14, 2009 | 08:14 PM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
Re: is my brake booster shot?
yes it is the power brake booster...do you hear alot of air coming from under the brake pedal? im having the same problem..my brakes are real hard and can hardly stop..got to push them real hard..there is NO power there what so ever..im replacing the brake booster this sunday. now im not sure if a 4th gen booster will work or not cant help you there..maybe someone else can answer that.
Old May 14, 2009 | 08:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
cool, though i can stop, but i cant lock the wheels up anymore.
the 4th gen pedal will work in our cars, so i see no reason why the booster wont.
I had a 4th gen booster bad when i did my engine swap, and decided to put the 3rd gen one back in and trashed the 4th gen one....stupid me
Old May 14, 2009 | 08:50 PM
gp90gta's Avatar
Car: 1990 GTA
I would do a vacuum test frist on then booster and check if it leaks down.What pedals do you have in the car? I dont know the geometry of the 4th gen pedals but if the lenth is different it will defentley change the amount of force applied to the hydraulic system.
Old May 15, 2009 | 05:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im using 3rd gen pedals, the 4th gen reference was just for bolt spacing.
i will do a vacuum test.
Old May 15, 2009 | 07:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well, i did a vacuum tst on the booster. I was able to get the gauge to 19.5 inches of vacuum and it stayed and didnt drop. So this is telling my that its ok?
Only thing i noticed was that the hose connected to the vacuum port on the booster was not clamped and was a little loose. Maybe it was leaking?
Next time i take the car out i'll see if there was any difference
Old May 17, 2009 | 07:43 PM
gp90gta's Avatar
Car: 1990 GTA
If the booster it self holds vacuum then dont forget to check the check valve (one way valve),and see if it hold vacuum too.Plus the rubber grommet can also have a leak. Some times the diafram in the booster will get week from just wear and tear,old age.
Well if the hose was loose then you may not have bin geting enough vacuum to the booster and it would explain why the pedal gets hard at 1" to 2" of pedal travel.Like when the booster is full of vacuum when u first shut the engine and you press the pedal,each time it gets harder and harder untill its empty.But if the hose was leaking the engine would be running lean,maybe even pin.I would check the plugs to varify.
-George
Old May 24, 2009 | 09:28 AM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
i have the opposite problem my peddle is so soft i can floor it and they wont lock up is that also the booster? i dont own a vac gague maby ill buy one today. what am i looking for as far as vac?
stock front (for now)LT1 rear with 3rd gen prop valve
Old May 24, 2009 | 09:43 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
That's more likely air in the lines or a bad master cylinder.
Old May 24, 2009 | 09:47 AM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Transmission: TH350
Axle/Gears: 4:11's
thats what i was thinking..bleed the brakes and see if that makes a difference.
Old May 24, 2009 | 09:50 AM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
flynbuy is going to make a small (not really small) fortune off me this week ill upgrade and let you guys know how it goes thanks for the quick replys!
Old May 25, 2009 | 11:25 AM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
I am having a similar problem and also wonder if it is my brake booster. If i hit the brake once it seems fine, the brake pedal travels normal distance but if i pump the brake pedal it gets hard and becomes difficult to stop. If i give it a few seconds though and then slowly apply pressure to the brakes the pedal will travel normal distance. any ideas?
Old May 25, 2009 | 12:17 PM
jv9999's Avatar
Engine: 5.7L/350
That sounds like the booster or low vacuum. What is your vacuum at idle?
Old May 29, 2009 | 11:39 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
an easy way to test your booster, without a gauge,
1.with the car off, pump the brake pedal til the brakes are hard to push.
2.with your foot still on the brake (with the brake still being hard to push) start the car, you should feel the booster engage.
if it does, your booster is working correctly, as for leaking or not,
1. take your foot off the brake, turn off the car.
2. let the car sit a minute, then push the brake, is it hard to push? it shouldn't be until depressed two or three times, getting progresssivly firmer
things to check
check the "check" valve that the vacuum line going to your booster hooks to, air should not move both ways though it, you should be able to suck air through it, but not blow it out. if you can, replace the valve, retest the system. if it still doesn't work, it's prob the booster.
Old May 29, 2009 | 06:11 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
things to check
what do you mean "feel the booster engage" kick back like my 04 seirra dose or fall to the floor like my camaro?
Old May 30, 2009 | 02:38 AM
ericjon262's Avatar
you will feel the booster suck the pedal down with the weight of your foot on it, without a ton of pressure on it.
Old May 30, 2009 | 01:02 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
could be the master bleeding pressure off.
replace both and call it a day.
brakes get annoying when trying to track down an issue.
get rid of it all and be done with it, IMO.
Old Oct 1, 2009 | 07:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well, im still screwing with this. Replaced the master, it was leaking anyway. Re plumbed things, installed a adjustable prop valve and gutted, cut, and welded the prop valve into just a junction block for the front brakes, removing the rear section entirely.
Brakes are exactly the same as before.
IT has to be the booster, everything else is new, and the calipers bleed and function properly.
The booster does hold vacuum without issues, but something isnt right. With the master removed, the brake pedal will travel all the way to the floor with slight resistance. Once the master is installed, with the engine running or not, the pedal moves about 1" to 1.5" and stops dead, i can stand on it and the firewall just bends and nothing else, the brakes blow.
Im going to have to pickup a new booster, unless there is something else to check.
Old Oct 4, 2009 | 01:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
to put an end to this sage once and for all, the issue was a leaky vacuum hose from the carb to the booster. I removed all the hoses and my auxiliary vacuum canister, ran a new short piece of hose from the carb to the booster and now i have brakes! Probably should have tried that a while ago, but everything is pretty new so i assumed the hoses were fine.
But im glad i did all the work, the new master looks really good, no more yellowed reservoir, it doesn't leak like the old one, and the adjustable prop valve for the rears is great. I need a lot or rear brake because of the massive steamrollers i have back there and the adjustment helps, stock bias just wasnt cutting it.
Old Oct 12, 2009 | 12:39 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
where did you pick up a new booster and master cylinder?
Old Nov 25, 2009 | 01:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Wow, all that work for a cracked hose
Great lesson for anyone that has to perform any maintenance of any kind.
Old Nov 25, 2009 | 08:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yea, it sucked, but since all the hose was new, i never though that it could be the problem
Old Nov 25, 2009 | 08:35 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Instead of replacing the booster with a stock vacuum booster, why not get a hydraulic brake booster? It'll finally make power steering a great feature to have.
http://www.performanceonline.com/sto...at=1032&page=1
That item is good for 67-92 Camaros/Firebirds
Old Nov 25, 2009 | 09:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
because what i have works very well now, and hydroboost is a ugly mess of hoses. And from what i hear, you dont get a very good pedal feels from hydroboost.
Also, i dont like the idea of running the brakes and the steering off the same pump. If the belt brakes, you lose steering and brakes. I would rather loose my brakes and be able to steer, or lose my steering and be able to stop than loose everything at once.
Old Nov 26, 2009 | 08:40 PM
Firebat's Avatar
You can get a re-manufactured 82-92 booster for under $100 from autozone. You can get a re-manufactured 82-92 master cylinder for under $30 from autozone. Re-manufactured is basically all new parts in an old core. If I would have known they were this cheap (and easy to replace), I would have replaced them in both of my thirdgens years ago even if they weren't completely shot.
Old Jun 14, 2010 | 05:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Didnt want to start a new thread yet, so I'll ask here.
I have a loud hissing sound, like air blowing out under my pedal when I press it.
I have C5 fronts and LS1 rears with stock 89 J65 disk brake proportioning valve and master/booster combo. All stock there.
I have no brakes. Car has good vacuum, the motor is not wild. Used to be ok stopping with stock front disks. Only thing I changed was C5 fronts. Bled the brakes good 2 times and still have no brakes. Wondering if my booster is bad.
I have similar conditions as above. Hard pedal. Does not travel down very far. Hard to stop the car. 30mph and it takes a good bit of distance to stop. Definately not safe.
Check valve is working, air cant blow in from the turbo boost but can open up under engine vacuum. I did not do a vacuum test however, not sure how to do that. Did notice it did not hold vacuum over night. Will try again however.
I did try pumping brakes with engine off to get all the vacuum out. Then while holding the pedal down hard, i started the car and it depressed just a little bit but I had alot of pressure on the pedal. Definately doesnt feel like it used to.
Any ideas? Do I need a different master and proportioning valve for this setup? Booster possibly bad now from alll the turbo downpipe heat?
Old Jun 14, 2010 | 07:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
sounds exactly like the problem i had, a vacuum leak between the booster and the intake/throttlebody/whatever.
the booster does make a woosh noise when you push the pedal, i think if the booster is bad, the pedal will just hit the floor.
Old Jun 14, 2010 | 10:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
vacuum line checks out. booster was pumped to 10 inch Hg with a little hand pump and it holds. I pressed pedal down one time and it dropped to 5. I guess its normal. So I assume the booster is working but the brakes are not. Hose is not leaking. I tested it. Its not a small hose either. Check valve works fine.
What else could it be if the brakes have been bleed right and still dont improve? Do C5/LS1 rear combos need a different master? Am I not getting enough pressure to the caliper?
Old Jun 15, 2010 | 08:01 AM
gp90gta's Avatar
Car: 1990 GTA
Leave the one way valve on but put a T on it in between the valve and the booster then put a guage on it, then use a vacuum pump or the engine to apply vacuum to the booster shut the engine off or if you use a vacuum pump disconect it make sure u put at least 14 hg on it then let it sit it should hold overnite if not you have a leak if it holds then press the pedal it should be soft if not then the diafram in the booster is weak and you'll need a new booster
Old Jun 15, 2010 | 08:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
From what I gather you changed the front 10.5" discs & iron calipers to 13" (?) discs and C5 calipers. Both of these calipers have 5 sq/in of piston area. So there isn't any difference in clamping ability.
The larger C5 rotor will increase brake leverage, providing more braking power.
The wild card in this is the brake pads. Are they decent/good pads, and more importantly, are they bedded in. With some pads it can take quite a while for them to get bedded to the rotors. And if they get glazed in the mean time, then need to start over getting them bedded (sand off pad face and re-install).
RBob.
Old Jun 15, 2010 | 12:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
RBob.
I have hawks hps pads up front. Just installed them and did some light driving but noticed they did not seem to stop so I stopped driving. I don't really see much signs of the rotors being marked up by the pads yet so not sure the pads are being applied with enough pressure. Not really sure what bedding is as I have never done a new brake system on a car before. I will look into it and test the booster for leaks overnight
Old Jun 16, 2010 | 01:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I notice my booster is not holding vacuum. I pumped it to 15 inches of Hg vacuum and it immediately starts bleed down some. It will slow at around 10 inches but definately does not hold overnight. Few hrs and its out.
So I guess I need a booster and possible bedding procedure. Any recommendations for a booster/master combo? Would a c4 vette or 4th gen setup work?
Old Jun 16, 2010 | 03:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the 4th gen master from an ls1 car works well, i think the 4th gen booster works too. Im still using a 3rd gen booster and its fine.
Old Jun 16, 2010 | 04:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Good thread, same boat as yall, everything has been changed but the prop valve and my brakes still work for crap. Though I can engine brake with the stick so I am able to still stop ok-ish.
checked the booster hose and nada
Only thing I got left to change is the prop valve, but sounds like thats not a 100% fix for this.
Feel like I got manual brakes but the booster is fine..........
Old Jul 5, 2014 | 09:37 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
When you replaced the booster was everthing ok? I have the same problem I have to push very hard for my car to stop and after about a inch or two it becomes hard!
Old Jul 6, 2014 | 12:01 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
on my adventure, I changed every single part of the brake system, last was to remove the still new looking fancy pads with some cheap $10 pads, it made the most difference.
Old May 30, 2015 | 02:10 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Is flyingbuy still in business? I just changed my front pads and rotors. Now I have a low brake pedal.
Old Jun 1, 2015 | 03:05 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Just a little note to anyone installing a new break booster. Paint it with a good quality paint unless you want it rust colored in a year or two.
dbrochard
Oct 3, 2015 12:43 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
