E brake vs. in gear
Old May 19, 2009 | 02:04 AM
gangsta_money23's Avatar
Car: 1982 Camaro Z-28
Transmission: manual
E brake vs. in gear
Ok so I've been wondering latey about putting the car in gear (manual of course) and then pulling the e brake. I was out with my dad the other day and his whole life (which is a pretty long time considering im about 20 now) he's just put his camaro into 1st when he parks never pulled the e brake. kinda suprised me as i always either pull the e brake or put in in gear when i pull the e brake. Will leaving it in gear withut the emergency brake actually stop the car from rolling? also on a hill would it not roll backwards? I would just go out and test it in my camaro but i dont wanna risk it not working and hitting something. I know I've left it only in gear without the e brake a few times but it was always on level ground and for very short times. Any opinions/ views on it? Just something I've been thinking about
Old May 19, 2009 | 02:49 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: E brake vs. in gear
If you put it in first or reverse, the drivetrain has a mechanical disadvantage to turning the engine, so it most likely won't roll. It is still possible, just really unlikely. Also, it won't roll backwards any easier than it will roll forwards. One thing to note is that the e-brakes are self-adjusting, but they must be used regularly to stay adjusted. I normally just use the e-brake, but on really steep hills, I do both, pull the e-brake and put it in first, but that's mostly because I don't trust the crappy 82-88 rear disc setup. It's not the best e-brake in the world, the 89+ is a better design.
Old May 19, 2009 | 10:34 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Get in the habit of using the parking brake or over time the cable may rust in place due the lack of use. Big problem if your state has inspections.
Old May 19, 2009 | 01:24 PM
I use mine all they time on both my cars, my dads the one who doesnt or never has i should say. I'd assume his has rusted especially by now since its been sitting for about 2 years
Old May 29, 2009 | 10:23 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I've never had a car roll away that was left in gear. I have had 3 different cars roll away (backwards) with the parking brake pulled. And they waited until I wasn't watching. I agree with your dad.
Old May 29, 2009 | 10:28 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i've never heard about this leaving in gear. well for manuals i have. my friend had a crappy 88 Cabriolet that he would leave in first. haha we used to push start it.
are you talking about just manuals or autos too?
i always use the E-brake in my camaro, same with the lumina.
though one time i looked out the window to my driveway to just look at my camaro. it wasnt there. i freaked out, ran outside, it was in the street.
my driveway doesnt even have that much of a slope.
Old May 29, 2009 | 10:29 PM
Convoy25's Avatar
nevermind, i just re-read it and saw manual. my mistake
Old May 30, 2009 | 12:40 AM
88iroc52387's Avatar
I do both, I've seen them roll in both cases. My buddy had a truck with bad compression, left in first gear and it rolled a good bit before he could hop back in it. I've also seen the parking brakes not hold and let the car roll. For some reason i've always done both. Can't say it was for any reason i've had my 4th gen roll away on me a couple times but usually becasue i forget to put the brake on or put her in gear. IF your worried about it throw both on its not like its time consuming to shut it off in gear and pull the e-brake up
Old May 30, 2009 | 11:15 AM
that'd suck to look out an have your car gone, only time mine ever rolled I was sitting in it and didnt realize i was on a hill, took the brake off before starting it on accident reached over and grabbed something from the glovebox and i started rolling forward, pretty suprising lol.
I plan on just stickin with doing both just cuz i dont wanna have any of mine roll away when Im not in em
Old May 30, 2009 | 01:55 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Owned manual camaros for a little over two years now, and none of them had E-brakes that worked. Thus, I always left it in reverse or first when parked, and I've never had a problem. Even left it in gear on a good 25 degree slope up a hill and left it for two days, never slipped.
Why don't you have some fun with this and put your car in gear, then have a bunch of friends try to push it forward (or backwards) then try it with only the E-brake. I'm willing to bet the E-brake will slip first.
Old May 30, 2009 | 04:15 PM
BiggRedd's Avatar
Car: 1986 Firebird
Engine: 2.8L
Transmission: 5Spd
My e-brake barely grabs. I parallel park facing downhill on ~45* hill almost daily. The e-brake will still allow a little roll so I throw it in first everytime. Thats how I was taught anyway. My
Old May 30, 2009 | 06:15 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
if you yank the ebrake on a front wheel drive car and put it in 1st or reverse you've got both axles covered. that's a lot of holding power.
my ebrake doesn't work on my camaro (yet) but I put it in first or reverse every time I park it and it never rolls. i would bet on the ebrake slipping before the powertrain. the ebrake only activates one shoe per side on drum brakes doesn't it? I'm pretty sure. no idea about how the rear disc set-up works, but I should find out. if I have to replace the wheel cylinders on my camaro i'm not doing it, i'm just converting to rear disc. I just got through replacing that same kind of wheel cylinder on my sister's S10. the ones with the metal clips. not again. **** that
Old May 30, 2009 | 08:58 PM
ACCLR8N's Avatar
Good idea!
Old Jun 6, 2009 | 09:17 PM
92Z28ZO31LE's Avatar
I have never used a parking brake ever. I let a friend borrow my 86 one day and I get a call"the rear end is on fire". They used the parking brake and it didn't fully release. That was a costly repair.
Old Jun 7, 2009 | 08:53 AM
ACCLR8N's Avatar
Been there, minus the fire part. The cables will stick if not used regularly. The handle isn't designed to push the cable back, it just releases the tension.
Old Jan 17, 2012 | 01:59 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Do both. Anyone that does only one is risking their car rolling. Anytime I teach someone, I always teach them to hold their foot on the brake, pull the e-brake, with the car off, put it in 1st or rev. Doing both ensures even if the cable fails, the car wont roll back. Risking in our old car that cable will hold is retarded at best.
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
