e-brake help
Old May 22, 2009 | 12:43 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
e-brake help
Swapped from an 87 GTA 10-bolt drum to an 89 9-bolt disc PBR.
How do I get the e-brake lines connected and working properly?
Old May 25, 2009 | 04:40 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: e-brake help
You need first design e-brake cables for a '88-90 car, bolt in installation. LMK if you need any help.
Ed
Old May 30, 2009 | 11:58 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: e-brake help
Ed
So the stock 89 PBR cables will work?
Old May 30, 2009 | 12:09 PM
transamice's Avatar
Car: 87 GTA t-top
Re: e-brake help
I went and bought the 89 front to back cable, meaning the line from the hand brake in the column and it should work fine.
I have the 89 e-brake lines for the calipers, just doesnt work with the 87 front cable.
Thanks Ed
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
