metric brake lines?
Old May 29, 2009 | 08:51 PM
corbettb4773's Avatar
Car: 91 camaro rs
Engine: 355 carbed
Transmission: turbo 350
Axle/Gears: BW 9 bolt 3.23
metric brake lines?
have 6mm rear brake lines on 91 camaro rs installed 9-bolt with pbr aluminum calipers and when I went to install pv on rear brakes my flaring tool would not fit the pipe has any one ever heard so also the car had drum brakes to start with just thought I would share this story
Old May 29, 2009 | 08:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: metric brake lines?
Welcome to TGO. Sorry, I'm a bit confused. If the 9-bolt had OE brake lines in place, the swap should have been direct, no need to flare anything.
JamesC
Old May 30, 2009 | 07:38 PM
Car: 91 camaro rs
Engine: 355 carbed
JamesC
had drum brakes went to install summit racing adjustable proportional valve and had to cut sorry unclear
Old May 30, 2009 | 07:40 PM
Car: 91 camaro rs
Engine: 355 carbed
had drum brakes went to add proportional valve and couldnt put on new pieces
Old May 31, 2009 | 01:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All thirdgens from 84+ have metric brake lines.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
