Proportioning valve question on 1LE conversion...
Old May 29, 2009 | 09:58 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
For you guys who've converted to 1LE front brakes on '89 and up cars with the factory rear PBR brakes - do you need a different proportioning valve?
Old May 29, 2009 | 10:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Proportioning valve question on 1LE conversion...
I'm not exactly answering your question; however, I converted to both the 1LE fronts and PBR rears. I use the 1LE proportioning valve along with what would be an OE master on an 89+ car. The link I provided elsewhere on the 1LE conversion also has info on PBR's (and what proportioning valve and master are required) that you may find interesting.
JamesC
Old Jun 4, 2009 | 09:32 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I have the same question.
I have a 91 GTA with factory PBR rear brakes and I'm thinking of installing 1LE front brakes. I believe its the same proportioning valve as I have right now.
JamesC, could you post a link?
Thx.
Old Jun 4, 2009 | 10:39 PM
Dokken10's Avatar
Car: 91 Formula
From what I have found in a search and in my parts catalog a 91-92 J65(front and rear disc) cars used the same P/V as an 1LE car.
Seems like 89-90 is a lot harder to figure out.
Old Jun 4, 2009 | 11:37 PM
chazman's Avatar
Axle/Gears: BW 3.45
I emailed Spohn. They said my prop valve would be fine.
Old Jun 4, 2009 | 11:53 PM
Dokken10's Avatar
Car: 91 Formula
It seems the main issue with P/Vs is the threads. Makes me wonder if there are any thread issues with the flex lines.
Old Jun 5, 2009 | 07:19 AM
JamesC's Avatar
The following link is the original how-to:
http://web.archive.org/web/200605221.../1LEbrake.html
The flex lines aren't an issue.
JamesC
Old Jun 5, 2009 | 01:31 PM
Dokken10's Avatar
Car: 91 Formula
The main issue is the thread count on the M/C, P/V and the short hard lines that connect them. The hard lines from the P/V to flex lines have the same thread count from 82-92?
Old Jun 5, 2009 | 02:16 PM
JamesC's Avatar
By flex lines, I'm talking about the line from hardline to caliper.
JamesC
Old Jun 5, 2009 | 02:47 PM
Dokken10's Avatar
Car: 91 Formula
Lets get on the same page. Listed in order starting at the M/C.
1. M/C
2. Short hardlines.
3. P/V
4. Hardlines to the flex(rubber, soft)lines.
5. Flex lines
6. Calipers.
Is the thread count the same where 4 and 5 connect the same from 82-92?
Or is it just the thread count between 1, 2 ,3 and 4 the issue between the years?
Old Jun 5, 2009 | 03:04 PM
JamesC's Avatar
1. M/C
2. Short hardlines.
3. P/V
5. Flex lines
6. Calipers.
I upgraded my 85 to 1LE. Because of thread count, I used the first design proportioning valve. It was a simple bolt-up to existing lines,(2 & 4). Since 82-83 had some SAE pieces, I'd guess 84+ are the same (5 & 6).
Old Jun 8, 2009 | 12:19 AM
Dokken10's Avatar
Car: 91 Formula
I'm more concerned about the 4 & 5 connection.
Old Jun 8, 2009 | 07:01 AM
JamesC's Avatar
I've never heard of anyone having issues there--I didn't.
JamesC
Old Dec 7, 2015 | 10:42 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Brining this thread back from the dead instead of starting a new one. Does anyone know for sure that the 1le, and 89-92 j65 cars use the same proportioning valve? I did a c4HD conversion on my car a few years ago, and braking has seemed to be sub par, and since this is basically the same as a 1LE setup I wanted to make sure I have the correct prop valve.
The car in question is 89 Iroc with J65.
Old Dec 7, 2015 | 11:03 AM
I keep getting mixed answers
According to this thread they are the same
https://www.thirdgen.org/forums/brak...-answered.html
Old Dec 7, 2015 | 11:31 AM
JamesC's Avatar
Aside from the first and second design which has to do with thread pitch, they're the same.
1st design: M1.0 tube nut threads (early 1989 applications).
2nd design: M1.5 tube nut threads (late 1989 through 92).
JamesC
Old Dec 8, 2015 | 05:22 PM
That's the answer I was hoping for thanks james
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
