Warped my rotors need new ones.
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
My rotors have gotten pretty bad. i just tap the brake and my steering wheel is doing the shake rattle and roll. I would like to upgrade to the sloted or cross drilled, they are a lil bit more expensive, but are they worth the upgrade? am I really going to see any improvement? is it worth spending a extra 50-100$ on each rotor. I have about 150$ maybe 200$ to spend, and Im pretty sure Ill need new wheel bearings, cuz i dont think you can reuse the old ones. Any
would be awesome just looking for some input and experience.
would be awesome just looking for some input and experience. Senior Member
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Warped my rotors need new ones.
You can reuse the bearings if they're good. Most rotors come with races already installed. Slotted and drilled rotors won't buy you much on a street driven car. Poor quality ones will be weaken than regular (non-slotted) ones.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Guest
Posts: n/a
Upgrade for what? Looks?
Just get some normal rotors if you really need them. Often you can just have the rotor cut to fix that. I've cut 1000's of rotors and none of them were warped beyond usable and they were always fine afterwards. I'd really question if yours are trash.
Might check your suspension too, loose parts just make the problem worse. The idler arm is the first thing I'd be checking real close.
Car: 88 Camaro
Engine: 305 TBI
I think they are pretty trashed, but I could be wrong about pretty trashed, im sure there are worst cases. Anyways I drive up and down a huge mountain every day and for the past month the shaking gets worst and worst. I cant even tap the brakes without it shuddering violently, and I feel the pulsing in the brake pedel. Its to the point now where if i tap them i have to hold onto the wheel or it will send me spinning. This is a shock to me because less then a year ago, i picked these rotors up new from Nappa "normal not sloted/drilled"
and all new bearings.
How much does turning the rotors cost?
thanks for your
so far !
thanks for your
so far ! Thread Starter
Car: 88 Camaro
Engine: 305 TBI
My whole front end is new, only part that is not new is my steering box and pitman arm. I do have a little play between the to. When im cruising at like 10-30 mph and have my windows down i can hear the rotor bouncing my pads around also. When im coming to a stop its like my brake pedel feels like a wack a mole game.
Guest
Posts: n/a
Wow thats pretty bad. What pads, napa as well? Know which ones?
It depends on where you go but usually $10-15 each to turn rotors. Its very easy to tell once they are on the machine how bad they are. You can check yourself if you have a dial indicator.
Car: 88 Camaro
Engine: 305 TBI
I got the duralast gold brake pads, lifetime warrenty, pads are pretty decent, got my rotors from nappa, im not sure which ones, they were approx 70$ each, think i spent probably 180 with new bearings.
If i can turn the rotors that would be awesome, save some serious cash, but is it worth turning them if the warped that quickly. wont they just warp again?
Guest
Posts: n/a
Turning the rotor will cut the buildup off the rotor. The section that has build up does not wear whereas the other 80-85% of the rotor circumference will wear leaving wuite a wobble feel and lots of cutting of that high spot off when turned. Once a rotor is damaged, the metal characteristic (conductivity or cooling charateristics) will change and not disipate heat as well in that hot spot section. Turning it will cut some of it off making it better, but it will never completely go away and will eventually retain pad buildup there again in the future.
Just try and cut them, and practice stopping habits as I mentioned above. If it coumes back within 3 months then toss them and buy new ones. AND ALWAYS REMEMBER- turn brand new rotors! New rotors are not machined to good tolerances and are not cut for quick pad break in. You need to hone cut them for fine tuning and break in. Never dio hard stops on new rotors until you have heat cycled the metal of the rotor for about 1 weeks daily driving. The metal needs to be conditioned to disipate heat properly by heating and cooling back off many times (thus heat cycling them)
Dean
Car: 88 Camaro
Engine: 305 TBI
thanks for all the info guys. Ill get em turned first and see how that goes, now just gotta find a place thats open on the weekends
Thanks for the info about how to warp them, maybe my driving warped them, i am pretty hard on the brakes at times!
Hey Rough,
We have stock replacement rotor and pad kits for your car with free shipping.They're inexpensive and will fix your warped rotor issue.
Chevy Camaro Rotor Kit
Car: 88 Camaro
Engine: 305 TBI
Hey Rough,
Pretty competitive prices, cant beat the free shipping, got a question for you Tony, do they come pre turned or will i have to have them turned?
Car: 88 Camaro
Engine: 305 TBI
Ok some members above suggested having to turn them before installation.
I think ill be landing
http://www.1aauto.com/1A/BrakeRotors...R00039/1188962
on payday.
on payday.
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Dean
Car: 92 Z-28
Transmission: THM700R4
Hold on! If you have to hold your wheel when you step on the brakes, it could be that your (probably original) rubber brake lines are toast and are not operating properly. Please consider replacing them w/ S/S ones or at least replace them w/ new rubber ones. They (new rubber ones) are inexpensive and this may just fix the majority of your problem. If the pedal is pulsating, it is due to rotors but having to hold onto the steering while braking problem is due to the old brake lines.
The only thing that you should need to do when you take a rotor out of the box is clean the protective coating off with brake cleaner.You shouldn't have to turn a brand new rotor.
Typically people turn rotors that are expensive to save money and to true up a warped rotor. The only problem with that is now the rotor is thinner and will warp easier once heated up again under hard braking conditions.
Tony
Tony
Guest
Posts: n/a
It depends on where the rotors came from in the first place and how they machined it. The Chinese stuff is just junk, turn them first or do not use them. The others are hit and miss, mostly related to how they machine them and how their maintenance is. Brake lathes surface both sides at the same time so if the machine is not worn out, the two surfaces will be parallel and 90 to the axle. Many manufacturers cut the surface with a stone cutter, and at least one does one surface at a time introducing a problem with surfaces being parallel (or not) out of the box. Usually the good rotors are within a few thousands and a light cleanup cut is all that is needed and has little effect on the minimum thickness. Way more is worn off in use. The store I worked at we did that for free with new rotors, if the customer wanted it done.
LT1Formula
Oct 8, 2015 08:34 PM
the_hamturdler
Sep 30, 2015 12:50 PM
