For those who have gone with braided steel lines: was it worth it?
Old Jun 11, 2009 | 11:14 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I'd like to hear what you guys think.....
Old Jun 11, 2009 | 06:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: For those who have gone with braided steel lines: was it worth it?
yes,
dont buy Russel's,
get earls.
Old Jun 11, 2009 | 06:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. Even a few feet's difference in stopping distance can be sufficient to avoid a collision.
JamesC
Old Jun 11, 2009 | 08:01 PM
chazman's Avatar
Axle/Gears: BW 3.45
The reason I'm asking is that I'm considering the Spohn 1LE kit. It gives you the option of Earl's steel lines for an extra $83.
How will performance be affected if only the front's get steel lines?
Old Jun 11, 2009 | 08:39 PM
JamesC's Avatar
Does your 89 have rear discs (PBR's)? If so, purchase the 1LE set (five lines) for $99, IIRC.
JamesC
Old Jun 11, 2009 | 08:56 PM
chazman's Avatar
Axle/Gears: BW 3.45
JamesC
Yes it does. Thanks.
Old Jun 11, 2009 | 09:11 PM
chazman's Avatar
Axle/Gears: BW 3.45
BTW, if the fronts get Hawk pads and the rears retain the "like new" stock pads - any issues?
Old Jun 12, 2009 | 06:43 AM
JamesC's Avatar
None that I'd be concerned about.
JamesC
Old Jun 29, 2009 | 11:05 PM
RTGTA's Avatar
Car: 2009 Silverado 1500
Engine: 5.3 Vortec
I went with Russell lines, even though i saw what happened to the one member's car..... sad to see. But my name is Russell, it's a good sign i thought
Old Apr 17, 2011 | 07:43 PM
Spin_Phoenix's Avatar
Car: 1984 Trans Am
Axle/Gears: Stock
RTGTA,
Any word on how your brake lines held up?
Old Apr 19, 2011 | 03:07 PM
mlopezformula's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
with braided steel line you get a better feel on the brake pedal, right??? also are these required when you upgrade you calipers?
Old Apr 19, 2011 | 03:10 PM
JamesC's Avatar
Some, I suppose.
No.
JamesC
Old Apr 19, 2011 | 11:20 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
I just replaced my fronts since my rear is from a 95 Z28(newer hoses). Just doing that I felt a big difference in braking feel, and it seems easier to stop(not as much pedal pressure). I still plan on getting an adj prop valve, and stainless hoses for the rear.
Old Apr 20, 2011 | 05:33 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
wow that help me out on planning my braking system
Old Apr 20, 2011 | 05:44 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I went with braided lines also about 10 years ago after I crushed the front driver OEM rubber line and locked up the caliper while driving. I did note something smelling hot for about 5 minutes before I came to a stop sign and pushed the front tire a good 1/2 mile with it squealing before getting it to a shop to pull over. I'm pretty sure mine were Earl's also.
I also went with the rear lines too. The pedal felt much more firm. Before it was a tad squishy at the very top. I still went with an adj prop valve also.
I'd probably rate the braided lines right up there behind the wonderbar install on how much you can feel it driving for little money spent.
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
