4gen caliper on 3gen Bracket Backing Plates
Car: workcar Legacy Cruising 84 trans am
Engine: Ls1 99 corvette
Transmission: update working to get a T56
Axle/Gears: 2004 GTO IRS
hi
does 1996 trans am caliper fit on a 89 "Iroc-Z" Caliper Bracket Backing Plates
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 4gen caliper on 3gen Bracket Backing Plates
that would be the rear backing plates, they wont fit the fronts.
yes rear backing plates
not sure what update on front I will do
well James I have drums and my trans am is 84
Ah. There's some info at the end of the following link that you might find useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
damn did 10 bolt come in 86 I sure that I have 9 bolt BW
Car: 86 Trans Am
just count the coverbolts, you never know what ended up in the car after 20+ years
my brother put the count at 10 bolt and now I need to open see if it is the same 4.11.1 axle and differentials that my brother put in it 10 years ago
and get the number from the cove box to what this Trans am came with
and the ercount is in 10 bolts
dose this mean that iron-z Bracket Backing Plates will not work?
It will be fun if Ed answers his pm
I´m typing in service parts identication numbers
so I need this from Ed
i have a 9 bolt, do the F body PBRs also hook up w/ the 3rd gen parking brake cables? I could swear the parking brake stuff is different on the later ones. I think i need 89-92 stuff for mine, including the backing plate since mine has the iron calipers and one side is leading, the other trailing (which looks ridiculous)
if I´m not wrong the Chevrolet Astro Van 4.11.1 has 33-spline axles is it Strong enough? for 350 rwhp
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, you need first design rear cables for your '87 and it's a bolt on deal. The leading/trailing thing allowed GM to use the same caliper on either side, lowering cost...and looking terrible.
Ed
What are 1st design rear cables? What year did they come on? I assume 88-92 w/ the pbr rear calipers?
Car: 87 GTA
Astro Van will mean leaf springs & no panhard bar, so a LOT of work fitting one in, regardless of the outcome. Might as well get a Ford 9" at that point, then your strength worries are pretty much over with.
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
ok heres one, will a 89 9bolt disc brake caliper fit a 98+ caliper bracket?
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
