Brake bleeding problem???
Old Jun 28, 2009 | 08:45 PM
Franchise's Avatar
Hey guys,
changed my calipers, AND tried to bleed, BUT nothing comes out...pulled the hoses at the caliper, pumped the brakes...nothing comes out!!
what should I do???
need to get the brakes working....
it is not my daily driver, BUT i am getting it back on its feet....
Please let me know what to do...
thanks,
Ron
Old Jun 28, 2009 | 09:07 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: Brake bleeding problem???
Is the pedal going all the way to the floor? Are the bleeders open all the way? Is the resevoir capped.......just dumb questions but try the stupid/simple stuff first
Old Jun 28, 2009 | 09:48 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the flex hoses break down internally , acting like a check valve . they can stop press. from passing or returning . ( happened to me ) they are keyed rt. & lt. , change them and you will be o.k. . might consider also change hose/hoses on the rear . a good flush of the entire system may also be in order . brake fluid that is NOT contaminated is clear , fluid that is not is not . good luck .
Old Jul 1, 2009 | 10:16 AM
Franchise's Avatar
THanks! it was those pesky hoses....so a trip to autozone and $25 later....bleed no prob.
thanks guys!
ROn
Old Sep 25, 2010 | 09:13 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
hmmmm... I'm having the same problem, but my rubber lines are brand new. I can pull out the bleeder, but don't get any fluid.....
Edit: Took off the new lines at the caliper, they're fine. Thought it was the caliper until I took off the bleeder & gave it several hard & fast pumps. I ended up with a puddle on the floor, but figured it out.
Old Sep 26, 2010 | 02:15 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The proportioning valve acts as a safety shutoff when there is a gross leak in either the front or rear brakes. It will travel to one end and prevent fluid movement to the low pressure side. To get past this you can either manually return the PV piston to the neutral position by pressing against the black rubber "button" at the rear end of the valve and gravity bleed the rear brake system to remove air and restore pressure. Or you can continue pumping the brake pedal until enough fluid moves past the valve to create pressure in the rear brake system. Youll know when the valve returns to neutral by pedal feel. Then continue brake bleeding.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
