FRONT SPINDLE? WHAT IS THAT?
Old Jul 26, 2009 | 01:57 PM
solarius49's Avatar
so im looking into buying my 1st firebird, its an 89. im buying it off of a fellow marine before he heads over to afghanistan, and he told me it needs a spindle where the rotor is on the front passenger side...can anybody give me some guidance to what it would take to replace this part?
Old Jul 26, 2009 | 02:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: FRONT SPINDLE? WHAT IS THAT?
you have to jack up the front of the car, support the a-arm. Remove the brakes, caliper and rotor. Unbolt the tie-rod, remove the strut. Remove the nut from the lower balljoint, use a pickle fork to remove the spindle. Reverse to re-install the new one.
Make absoultly sure the issue is the spindle and not subframe damage. The spindles are really tought parts and breaking or damaging them takes a lot. If the spindle was broken, chances are there is more damage to the subframe/k-member.
or better question, why does he say it needs a new spindle?
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Ghettobird52
Apr 21, 2020 08:44 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
