brake problem
Old Aug 17, 2009 | 09:13 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
brake problem
hi i have an 84 camaro stock front brake components. i have a problem with the passenger side squeaking while i drive, squeaks when i turn the wheel while driving to the left, and when i go to stop. what causes that? its onlt the passenger side. i replaced caliper, pads, rubber brake line that goes from hard to the caliper line and still does it.
Old Aug 17, 2009 | 10:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: brake problem
How are the bearings?
JamesC
Old Aug 17, 2009 | 10:58 AM
Engine: 355
Re: brake problem
to be honest i have no idea how to check to see if they are even bad. u know how?
Old Aug 17, 2009 | 11:10 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: brake problem
check the brake fluid??
Old Aug 17, 2009 | 11:15 AM
Engine: 355
Re: brake problem
its full with brake fluid
Old Aug 17, 2009 | 11:16 AM
JamesC's Avatar
Re: brake problem
Jack the car up. Grab the wheel at the 10 and 4 position and try to wiggle the wheel/tire. If there's movement, the wheel bearing is probably the culprit.
JamesC
Old Aug 17, 2009 | 06:41 PM
Engine: 355
Re: brake problem
ok. i jacked the car up, theres no wiggle room there solid. i noticed that if i grab the wheel and spin itll only free spin for maybe a 1/2 to 3/4 turn and then stop. it does it with both the front wheels. while doing it theres a slight rubbing/grinding of metal to metal. is that normal? are my calipers still in the closed position? thanks
Old Aug 17, 2009 | 07:56 PM
Engine: 355
Re: brake problem
i looked at it again and the pads are sitting on the rotors. there new calipers, what will cause them not to retract? is my master cylinder failing or is it another problem?
Old Aug 17, 2009 | 08:59 PM
JamesC's Avatar
Re: brake problem
Sounds normal.
JamesC
Old Aug 18, 2009 | 09:19 AM
Engine: 355
Re: brake problem
a rubbing and scrapping noise is normal? it has quite a bit of resistance when i spin it. thats normal?
Old Aug 18, 2009 | 11:04 AM
JamesC's Avatar
Re: brake problem
There'll be a slight brushing/scrapping sound from the pads lightly touching the rotors. Normal.
JamesC
Old Aug 18, 2009 | 11:26 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: brake problem
try pulling the caliper off one side and spin the wheel to eliminate the bearings (they may be too tight and coming apart) .
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
