squeal squeak
Old Sep 13, 2009 | 12:42 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
squeal squeak
so i get the brake grind squeal squeak blues here. took off the wheels looked at the pads and rotors all good in the front. took off the back wheel drums and shoes are all good. it doesnt make noise all the time just sometimes. i remember when i did my front brakes a while ago i lost a spacer i think in the front passenger side caliper. and i went under way for 6 months shortly after that. the rotors had a light coat of surface rust on them. the rust is gone as i have driven the car. would that missing spacer be the cause of my squeal sqeak grind? i can get one made easily if i need to.
Old Jul 7, 2011 | 05:27 PM
RoosterC's Avatar
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
Re: squeal squeak
if you've heard anything about that, please let me know. I'm quite literally in the same boat as you XD
86TpiTransAm
Nov 17, 2001 11:49 AM
Jason86Z28
Jul 1, 2001 10:18 PM
V-6 fbird
Feb 14, 2001 06:09 PM
NewYorker
Aug 1, 2000 08:34 PM
1iroc2slow4me
Jul 26, 2000 11:40 PM
