You looking for crazy bubble flare fittings?
Old Sep 22, 2009 | 08:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
check these guys out, just found them the other day and they have everything, even a 14mm 1.5 bubble flare union that i've been looking for for a couple months. Ordered monday and should have a bunch of parts tomorrow! seems like a great company
http://store.fedhillusa.com/316475mmtubingandnuts.aspx
Old Sep 27, 2009 | 03:33 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: You looking for crazy bubble flare fittings?
I have a 85 Z28 W/ factory front disc and drum rear...I recently bought a 9 bolt rear with PBR Discs. My prop valve is round shape and the rear brake line attaches to the front of it. Is this the standard double flare prop valve or did they make these metric too. I have one of those aluminium flat on both sides prop valves that came off a 91 and I'm not sure if my brake lines will match up to this prop valve. please advise
Thanks!!!
Old Sep 27, 2009 | 12:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the roundish propvalves are SAE thread, so they would be inverted flare IIRC. The later ones are square machined pieces and are metric threaded with bubble flares
Old Oct 4, 2009 | 02:26 AM
85 ZXX's Avatar
Thanks for the info!!!
83 Crossfire TA
Jan 3, 2016 01:26 PM
New2Chevy
Sep 28, 2015 12:35 AM
tglennon11
Sep 23, 2015 05:30 PM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
