Going to remove LT1 brakes off a donor rear, what do i need to take?
Old Oct 10, 2009 | 01:55 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I saw a 94 LT1 Z28 at the junkyard today that still had it's rear disc's. What all do i need to take off it so i can install the disc's on my drum brake rear? Thanks!
Old Oct 10, 2009 | 02:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Going to remove LT1 brakes off a donor rear, what do i need to take?
Won't work without modification or without purchasing a kit from Ed Miller. More food for thought in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Oct 10, 2009 | 03:22 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Thanks again, that link is very informative!
Old Oct 22, 2009 | 01:05 PM
AlwaysSidewayz's Avatar
i dont know, i got the 12" rears on my diff, because my old one went out and im chill with the people at pick n pull and they didnt charge me extra. those rears are beefy though, bigger the the stock fronts!
Old Nov 3, 2009 | 02:14 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
I took the brakes off along with the ebrake cables, will i be able to use the ebrake cables or will i have to use a different set up?
Old Nov 3, 2009 | 08:37 PM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
Those E-brake cables won't work, you're going to wait untill Ed starts selling the updated design cables.
Old Nov 11, 2009 | 06:22 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
So the e-brakes wont work? I took the e-brake handle and the cable that connects to the handle to the two cables comming off the calipers. If i use the whole e-brake assembly would i be able to get it to work?
Old Nov 11, 2009 | 06:35 PM
Stephen's Avatar
Car: 87 GTA
Coulda just swapped the entire rear axle. Better center section, if you haven't upgraded yours already.
Old Nov 14, 2009 | 02:58 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Did that for my LS1 brakes. I have the entire e-brake assembly from handle to wheel, including all the brackets (the tunnel bracket too).
Old Nov 16, 2009 | 11:25 AM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Did that work for you?
Old Nov 16, 2009 | 01:38 PM
Al Hasse's Avatar
Works fine. This is the 4th gen tunnel bracket with 4th gen cables. You can see the remains of the old bracket and the cable guides still in place. I bolted it in place with the intention of welding it in later.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Reddeath210
Oct 6, 2015 08:20 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
