Brake Lines 4th Gen Rear
Old Oct 15, 2009 | 10:59 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I installed the 4th Gen rear (2000 Z28) in my 91 GTA, which was a cake walk. However, the rear did not come with brake lines and Finelines/others do not make them.
What would be the best way to put brake lines on the car? Is there a kit or should I just get an fittings and braided stainless steel hose?
Your help is much appreciated!
Old Oct 15, 2009 | 11:31 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Brake Lines 4th Gen Rear
Can you find brake lines for a 4th gen rear from another donor car/rear? Maybe adapt thirdgen lines to it?
Else I'd probly by some brake line tubing/flare tool/etc and fab up your own set.
Old Oct 15, 2009 | 03:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
3rd gen drum lines should be long enough, but you will have to tweak the ends a little bit.
dont use flex lines for the entire run, the pedal will be spongy
Old Oct 15, 2009 | 04:08 PM
Stephen's Avatar
Car: 87 GTA
Don't drum brakes use a hard line al the way to the shoes? So you'd hafta add a flex/rubber end, to go from the hard line to the caliper itself.
Old Oct 15, 2009 | 06:13 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If you got the brake line brackets that fit over the lower control arm brakets your in business. The rubber flex lines are readily available, and then it's a simple matter to make up the hard lines from the flex hoses to the T fitting. You can rent flaring tools from a parts store. I modified the 4th gen lines when I put the LS1 style disks on my 3rd gen rear. Was really easy and worked out very well for me.
Old Oct 15, 2009 | 06:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yes they do,
you need the flex hoses for the 4th gen calipers, i assumed the OP knew he needed flex hoses for the calipers
Old Oct 16, 2009 | 05:20 PM
wildjyoung's Avatar
Thanks guys! I will jsut mock up something by myself. I have an odd combination of parts that I was trying to make work. However, I think it is best to just start fresh and fab something.
I have braided steel lines for brakes that are 3an to bubble flare. I also have the adapter that goes from the 10mm banjo bolt in the caliper to 3an. So, I think I am going to connect the 3an fitting to the caliper adapter and then run a hard line to the T on the axle. However, most hard lines have inverted flares correct? Thoughts?
Josh
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
