Front caliper bleeder screw size
Old Nov 23, 2009 | 06:52 AM
GhostRider_fr's Avatar
Hi there !
The bleeder screws of the front calipers of my 1988 350 ci Iroc-Z are dead.
Could someone please tell me their size, so that I can buy new ones ?
Thansk in advance for your answers !
Old Nov 23, 2009 | 07:10 AM
blackroc68's Avatar
Re: Front caliper bleeder screw size
10mm/1.5
Old Nov 23, 2009 | 09:42 AM
Thanks a lot for your help !
As this is a metric screw, I guess it should'nt be a problem for me to find these
Old Dec 2, 2018 | 08:53 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
.its only a problem when bleeding the rear brake on that side..makes a mess.. what I did with all the work I put in on mine. was mark and drill a hole in the 2 plates. to run the tube over the end of the bleeder.. 1st plate is the one you see the 2nd plate is at a angle on the under side..I only did this to keep things clean. when putting the car back together..and setting the rear brakes back on the car.. but on a side note..the outer plate was never a issue..
the last thing I wanted was blake fluid spashing all over..
1992rs/ss
Jan 31, 2025 05:10 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
knight72
Aug 10, 2015 09:32 PM
