Brake lines - 9 bolt PBR disc to 10 bolt drum
So my 9 bolt is gettin a little old, and I got a great deal on a 10 bolt drum with a 3.42 Torsen diff already installed. Picked up some mounting brackets from Ed miller, and am hoping to do the swap soon. The 10 bolt does NOT have brake lines. I had planned on swapping over all the lines from the 9 bolt. Parking brake cables too. SOOOO much info via search it was hard to sort though. Anyone have any thoughts on this?
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Brake lines - 9 bolt PBR disc to 10 bolt drum
If both are drums and they both use the same slave cylinder (or atleast the same size fitting) you should be able to move the brake lines over, may need to do a little bending and tweaking. Possibly tack on some new clips but shouldn't be too much effort. Not sure on the parking brake cables. Maybe look on something like rock auto and see if they list different part numbers between the 9 bolt car and the 10 bolt car.
The flares on the rear brake lines are pretty simple so if they don't work you could borrow a flair tool and buy some straight line. I would suggest getting new rubber hose (or braided line) to replace the soft line between the body hard line and the hard line on the axle. This and the soft lines on the front make for a softer pedal.
I have a 9 bolt PBR disc. I'm swapping those brakes over to my new 10 bolt drum rear. I have the brackets for the calipers. Is there any reason that I can't use my existing brakelines? Essentially the ENTIRE braking system will remain unchanged. I don't see why there would be an issue, I just figured I'd ask.
Car: 1989 Firebird
Engine: 5.7 LS1
Should be good as long as the brake end brackets will mount to the 10 bolt, I don't recall. Your only issue might be a slight width difference but you should have enough flex in the lines.
You might when be able to unclip the lines from the existing axle and zip tie your calipers to the car and not even open the brakes. Drop the axle and put in new one and reinstall the brakes.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
I apologize as I have clearly misrepresented my goal. I currently HAVE PBR discs, and I'm swapping them over to the 10 bolt. Calipers, lines, rotors, pads and all. The only reason I mention that the 10 bolt has (had) drums was in the event that somehow the drum rear housing was different than the disc rear, and it somehow affected the lines. I don't see HOW it would matter, but stranger things have happened in the world of thirdgens.
If the brake lines don't just swap right over, it shouldn't be too difficult to tweak them, or bend straight lengths from the parts store. Reproductions are available too, IIRC. I'd throw up a picture of the 10-bolt PBR lines, but mine are in the attic with a vaguely Firebird shaped modern art master-piece parked under the attic ladder...
The 9- and 10-bolt PBR braking systems are identical. I used 9-bolt lines when I converted to PBRs on my 10-bolt.
Rob Dog
Sep 3, 2007 05:01 PM
Rob Dog
Dec 31, 2006 02:59 AM
