Front LS1 rotor ???s
Old Dec 24, 2009 | 10:00 AM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I am collecting parts for my front LS1 upgrade. Have all the caliper parts.
Was wondering if these calipers would work with a 13" c4/c5 rotor with the right brackets or if I was stuck using the 12" LS1 rotors.
Old Dec 24, 2009 | 12:04 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Front LS1 rotor ???s
Eb Miller would know... He's around here on the brake boards usually.. I bought my LS1 kit from him and the brakes are 10x better than stock... Night and day difference.. I used the 12" rotors though.
Old Dec 24, 2009 | 02:16 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think you can put corvette calipers in the LS1 caliper brackets from what I understand. So you're not stuck per se... but the calipers wont work.
Old Dec 30, 2009 | 07:33 PM
seiplentz's Avatar
Car: 85 Z28
Ok thanks I was looking to see if 13" rotors would work with the ls1 calipers if not I will just stick with the standard ls1 conversion.
It will still sure beat the stockers.
Cant wait to get started spring will come fast!!
Also if knows I am looking for caliper rebuild kits for the ls1s. I have found them on rock auto but they want my arm for shipping.
Old Dec 31, 2009 | 02:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, with the correct brackets you can use a larger rotor.
E
Old Dec 31, 2009 | 04:00 PM
seiplentz's Avatar
Car: 85 Z28
So if I bought the c4 hd conversion brackets from your site with the 13" c4 rotors I can still use the LS1 caliper setup? (calipers and caliper brackets)
Old Jan 1, 2010 | 05:43 AM
ebmiller88's Avatar
Not that simple but it's the correct concept, yes. It'll take a new bracket as the C4 and LS1 parts won't interchange as simple as LS1 and C5/C6 parts do.
Ed
Old Jan 4, 2010 | 03:32 PM
Zedsled's Avatar
Car: 84 Z28
Engine: Modded 350ci.
just to save a new thread(not trying to hijack)
with the 82-92 LS1 spindle conversion, with the new hub would i still need the spacers for my 17x9 SS/WS6 wheels?
Old Jan 4, 2010 | 05:45 PM
seiplentz's Avatar
Car: 85 Z28
I don't know for sure but I would say yes. your only adding the thickness of a rotor between the hub and the wheel.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
