usa vs canada built Camaro. Parking brake cable
Old Jan 12, 2010 | 05:51 PM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I am looking to buy a left rear parking brake cable and the auto parts store asked if my car was built in Canada or the United States.
My car is not accessable so I cant check. Is there even a difference between the parking brake set up between the states built and canada built cars?
My main question is will a US e-brake work for both builds?
thanks a lot
Old Jan 12, 2010 | 06:03 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: usa vs canada built Camaro. Parking brake cable
Here is some more info.
The cable they have is "made for american market"
It's made by raybestos
model number: BC93084
A picture is attatched.
Is there any way to tell if the car is made in Canada or the States by the physical features of the car.
Attached Thumbnails usa vs canada built Camaro. Parking brake cable-parking-brake-cable-lr
Old Jan 12, 2010 | 08:25 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Anyone have an idea?
Old Jan 12, 2010 | 08:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
IIRC the sticker on the outer jamb of the driver door states the country of origin. IIRC (again), my '92 was built in Canada. And it is a US model car.
RBob.
Old Jan 12, 2010 | 09:06 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
ok so you found out it was made in canada because of the door jamb. But how did you find out it was an US model?
Old Jan 12, 2010 | 11:52 PM
GeneralLC's Avatar
Car: 1987 Camaro Sport Coupe
Engine: None
One obvious thing is that Canadian cars have speedometers which have the bigger white numbers in KPH compared to American ones which have it in MPH.
Canadian cars will also have an extra digit in the odometer because they are in kilometers.
Old Jan 13, 2010 | 04:45 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
well both my gas guage and speedo are in both km/h and mph, liters and gallons.
the guages have 2 arrows connected in the middle
Old Jan 13, 2010 | 05:05 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
If the first number in the VIn is a 1 it was for the USA, if it's a 2 it for Canada.
Vehicle Identification Number Example: 1G1FP2184NL100000
First Digit Nation of Origin: 1=USA, 2=Canada
Second Digit Division: G=General Motors
Third Digit: 1=Chevrolet, 7=GM of Canada('83-'88)
Fourth & Fifth Digit Body Style: FP=Camaro Sport Coupe, FS=Firebird, FW=Trans Am
Six Digit: 2=Hatchback, 3=Convertible
Seventh Restraint Codes: 1=Manual Belts, 2 or 3=Manual w/ Driver Air Bag, 4=Auto Belts
Eigth Digit Engine: See Engine Codes Below
Ninth Digit is Check digit
Tenth Digit Year: H=87, J=88, K=89, L=90, M=91, N=92
Eleventh Digit Production Plant: N=Norwood,Ohio, L=Van Nuys
Last Six Digits increase by one with each car built at each plant
Old Jan 13, 2010 | 08:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It was purchased new in '92 from a dealer in the US. I figured that it would have to be a US model for that to be done. If the cover isn't frozen to the car I'll take a look at the door jamb later today and post back on what it says.
RBob.
Old Jan 13, 2010 | 09:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I was wrong about the car being built in Canada, along with the info on the door jamb. There are two stickers on the jamb. One states the tire size/pressures along with the gross vehicle weights (ft/rr). The other sticker has the VIN and the year of the vehicle along with stating that it meets all US regulations concerning bumpers, safety equipment and so on.
As far as where the car was made, well, it was made all over the world with the final assembly done in Van Nuys Ca, USA. This is from the window sticker:
"This GM product, including all components, is produced for Chevrolet by various GM operation and suppliers to GM worldwide."
"FINAL ASSEMBLY VAN NUYS CA. USA"
What the auto parts store may be looking for is the market rather then where the car was built. So the door jamb sticker may still help as it would (hopefully) designate the intended market country. Instead of stating it meets US regulations, it would say it meets Canadian regulations.
RBob.
Old Jan 13, 2010 | 10:56 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No thirdgens were built in Canada.
Old Jan 13, 2010 | 11:34 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thanks for all the info guys. I think it will work for my car. Ill post back if it doesn't.
Any additional info would still be helpful
Thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
