looking for brake upgrade w/fact. wheels, already seached
Old Jan 24, 2010 | 10:34 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
hey guys, I already did a SEARCH, couldn't find the answer I am looking for. I am trying to find which upgrade for my brakes will fit my factory Iroc wheels. Yes I know of the thread that shows what size will fit, but I am trying to find out which setup will still run the seperate front and rear wheel setup. I know also that 1le setups and so on use 4 rear wheels on the car, and I don't want to do this (wheels all polished and powder coated). So does anyone know of a brake upgrade (12" prefered), that will fit factory wheels with seperate front and rear wheel????
Thanks guys.
Old Jan 25, 2010 | 09:42 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: looking for brake upgrade w/fact. wheels, already seached
the ls1 brakes should fit at least that is what I read on here. definite improvement from stock.
Old Jan 26, 2010 | 02:27 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
but the LS1 front kit pushes the stock wheel 1/2" out. Why not just do the 89 and later PBR swap if you want something close to a 12" setup? If it would for some reason push the wheels out it won't be noticeable to the naked eye.
Old Jan 26, 2010 | 02:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
91, someone fed you baloney. I run the 1LE set-up all around. Stock IROC wheels, both front and rear, fit fine. Check the pics below (or my Car Details for more). The wheels are marked "rear" in the first pic and "front" in the second.
JamesC
Attached Thumbnails looking for brake upgrade w/fact. wheels, already seached-100_0771.jpg   looking for brake upgrade w/fact. wheels, already seached-100_0772.jpg
Old Jan 26, 2010 | 09:11 PM
Engine: L98 494hp
Originally Posted by JamesC
91, someone fed you baloney. I run the 1LE set-up all around. Stock IROC wheels, both front and rear, fit fine. Check the pics below (or my Car Details for more). The wheels are marked rear in the first pic and front in the second.
JamesC
no not the size or style of iroc wheel, but the different offset front/rear.....you should be running four REAR wheels.....I have the seperate FRONT and REAR wheels.....the front wheels being a different offset than rear.
That's why I haven't switched to 1LE Already....
racing geek....that might be what I'm looking for....hate to ask but you happen to have a link or info. I'll do a search too....thanks
Old Jan 26, 2010 | 09:13 PM
JamesC's Avatar
Yes, I have different offsets, front and rear, like all OE IROC wheels (as a consequence of that offset, the wheels are marked "front" and "rear"). No need to run four rear wheels with the 1LE set-up.
JamesC
Old Jan 26, 2010 | 09:20 PM
Engine: L98 494hp
really....I always thought that 1le cars ran four rear wheels....my neighbor has a '91 1le and it has four rears on it....weird. So you have the 12" brakes then....
Old Jan 26, 2010 | 09:31 PM
JamesC's Avatar
The neighbor may be running four in order to more easily rotate the tires, but 1LE brakes certainly don't require them. The 1LE rotors are often called 12" but are actually a bit less than that.
JamesC
Old Jan 26, 2010 | 10:01 PM
Engine: L98 494hp
like 11.5 inch right?? Now here is another question....if I rotate my rear wheels to the front, the wheels sits way far inside the wheel well ....(I just went out and checked, my car is on jack stands and wheels off) the rear doesn't fit the front.
And then I just walked next door and double checked, his does have four rear wheels for sure....it looks like the 1le hubs sit farther out than mine do. So I'll need new spindles too, but what about his hub being farther out than mine.....If I put my front wheel on his car, it sticks way out, like and inch or something (we tried once cause he wanted to buy my wheels at one point)....is there two different 1le style brakes.\
not trying to doubt you but just got some weird questions
Old Jan 26, 2010 | 10:38 PM
Car: 1987 IROC-Z
Transmission: TH350
JamesC
In order to continue using the stock wheels on your car, why not just purchase two thin slip on spacers to get the correct offset for the front wheels? I can't remember what the correct thickness is offhand, but it won't cost much for the spacers.
Old Jan 26, 2010 | 10:45 PM
Engine: L98 494hp
but my rear wheel won't fit on the front of my car......how does his fit on the front of his car?? I'm confused???
Old Jan 26, 2010 | 11:04 PM
Engine: L98 494hp
so what do I need, 1le calipers, rotors/hub,pads, spindles...and steering knuckles??
Old Jan 26, 2010 | 11:54 PM
Car: 1987 IROC-Z
Transmission: TH350
If you are saying your back wheel is getting placed further in the wheel well, just use a spacer to bring it out a little.
The spindles are steering knuckles are the same thing and I don't think those would have to be changed anyway. I think it's just a little bit of modification that needs to be done such as drilling two holes larger and tapping it for new threads. I could be wrong on the modification part though.
Why are you only going to do the 1LE setup? You can get a larger brake setup under the IROC wheels.
Old Jan 27, 2010 | 06:51 AM
JamesC's Avatar
The 1LE spindles are OE spindles, like all thirdgens are equipped with, except the ears are cut off and the dust shield holes are drilled and tapped. Put the brake parts on the spindles and bolt up the wheels: Fronts on front and rears on rear. No spacers are required, period. This is a straightforward bolt-up swap (except for the drilling/tapping). Check the first thread in the following link for more info on the fronts (the rest of the link concerns swapping in 1LE rears):
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
EDIT: IIRC, the 1LE fronts push the wheel out about 1/4". At any rate, the 1/4" doesn't change wheel fitment with the proper OE wheel orientation. There aren't two different 1LE front brake options.
BTW, are you sure your neighbor isn't running four fronts?
JamesC
Old Jan 27, 2010 | 10:58 AM
Engine: L98 494hp
no, it's four rears for sure...says rear on all of them...and he has the bigger brakes. That's weird, I wonder why his car can allow this......it's all factory looking, wheels look all in the correct space.
I'll check out that thread, and then order me some brakes. thanks
Old Jan 27, 2010 | 12:22 PM
TTA579's Avatar
Car: Turbo Trans Am #579
Engine: 231ci (3.8L) LC2 (Buick Turbo)
Transmission: 200r4
Axle/Gears: Borg-Warner 9-bolt
Spacers. If I'm understanding this thread properly, you could put rears on the front with a set of spacers to get the correct positioning.
Either stop worrying how your neighbor has managed to do whatever he's done, or go over there and ask him. You do not need 4 rears for the 1LE brakes.
Old Jan 27, 2010 | 11:36 PM
Engine: L98 494hp
cool, I'll try to find all the parts to put this together....if all the parts are still available. Thanks guys.
Old Jan 28, 2010 | 12:31 AM
Car: 1987 IROC-Z
Transmission: TH350
I know ebmiller sells the 1LE kit. It's really expensive but he has it.
Front:
http://www.flynbye.com/catalog/i55.html
Rear:
http://www.flynbye.com/catalog/i10.html
I pieced together my entire C5 front kit for less then half of the front 1LE kit ebmiller sells (~$300). When I had the LS1 kit pieced together, I had the whole package for ~$250. Just some fyi...
Old Jan 28, 2010 | 10:07 PM
Engine: L98 494hp
I can do $300 no problem....what is involved in that. Is that the one where you mill down a factory hub?? And then you have to make a new brake caliper bracket , correct??
I have the pbr rears already (come on '91 stock)
THanks for all your guys help.
Old Jan 28, 2010 | 11:58 PM
Car: 1987 IROC-Z
Transmission: TH350
What is involved with the C5 front kit? At least 17' wheels, cutting down a stock rotor to get the hub, making/buying the caliper adapter bracket, finding C5 calipers, buying some C5 rotors, installing new bearings and grease, modifying the stock spindles (drilling and retapping two holes and cutting parts off)... I think that's everything. The 17" wheel part is probably whats going to put you off, but you can just go with the LS1 front kit then. It gets you a 12" rotor instead of the 11.6" rotors from the PBR setup and it also gets you a stronger and cheaper ($$ wise) caliper. If you're doing a front brake upgrade, I really don't see any point in doing something worse then the LS1 setup since it can be done so cheap. If you do a lot of track days with the car, you want to consider using C5 calipers with the LS1 rotor since the LS1 calipers have the tendency to spread when they have a lot of heat put into them. There is no reason to worry about this on a cruiser or daily driver vehicle... only if you do a lot of track days.
The reason I went with the C5 kit over the LS1 is because of all the track time my car sees and because I was going to be running 18" wheels anyway. I was actually thinking about running the 14" C6 rotor with the C5 calipers just because I have the room in my wheels and I may need the extra rotor mass when I get the car on Road America.
That's what we're here for!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
