LT1 master cylinder to stock proportion valve and lines?
Old Feb 8, 2010 | 10:34 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I know a lot of people are running ls1 master cylinder that hook right up, i also know there are some that have used the LT1 master cylinders but they arent a direct bolt up due to the fitting sizes. For thos using the LT1 master cylinder how did you hook up the lines, or what fittings or adapters did you uses etc. i got a LT1 booster and master cylinder from a friend and i want to use both on mine.
Old Feb 9, 2010 | 10:17 AM
FueledSoul's Avatar
Re: LT1 master cylinder to stock proportion valve and lines?
anyone? *srugs*
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
