Ed, I'm still interested in Wilwood FSL based setup for 9 bolt.
Old Feb 18, 2010 | 12:23 AM
87350IROC's Avatar
Car: 87' IROC
Hey Ed,
About 6 months ago I ordered your Wilwood FSL front setup. At the time we discussed you coming up with a matching set for the rear. Do you still have interest in doing this? I have cash in hand.
I would be interested in running as big of rotors as possible that will still fit my 16" IROC wheels. My requirements would be:
- FSL or Dynalite calipers
- must have working e-brake (hopefully better than stock)
- must fit 16" IROC wheels
- must fit 9 bolt
- rotor must be available in DBA 4000 series (to match my fronts)
So what do you say? I realize the market is a bit limited for such a setup, but I'd be willing to throw some extra money your way to make this happen.
Thanks.
Old Mar 9, 2010 | 07:00 PM
87350IROC's Avatar
Car: 87' IROC
Re: Ed, I'm still interested in Wilwood FSL based setup for 9 bolt.
to the top ^^^
Old Apr 27, 2010 | 01:55 AM
87350IROC's Avatar
Car: 87' IROC
to the top ^^^
Old Apr 27, 2010 | 02:08 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I hear ya. I just sent off the pattern for C5 rear conversion brackets for 9 bolts and I'll go off in other directions from there. Ideally I would like to use a C5 rear rotor and FSL caliper so this is the route I'll take at this time. I have a LOT of stuff going on.... thanks!
Ed
Old May 7, 2010 | 09:40 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would be interested in this as well. I have the 12" Wilwood FSL on the front and stock style 12" brakes on the rear but I would like matching calipers on the rear too, I also have a 9 bolt
Old May 10, 2010 | 01:48 PM
87350IROC's Avatar
Car: 87' IROC
I was just working on my stock rear iron brakes yesterday. And they reminded how terrible they are and what a pain they are to work on.
John,
Dreaming of Wilwoods.
Old May 13, 2010 | 01:58 AM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Ed
I would be VERY interested in the C5 rear set up. Does it keep the e-brake?
Old May 13, 2010 | 10:14 AM
87350IROC's Avatar
Car: 87' IROC
The proposed C5 rear setup uses the C5 e-brake. Do a search, there is a lot of info for the C5 swap for 10 bolts. Please keep this thread dedicated to a Wilwood swap.
Old May 13, 2010 | 09:19 PM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
OK, a bit sensitive? I posted in here because I am also using a 9 bolt, so I figured it was related.
Old May 14, 2010 | 10:19 AM
87350IROC's Avatar
Car: 87' IROC
I'm not sure how answering your question and telling you a place where you can get more information is considered being sensitive. If you don't appreciate me answering your questions let me know, then I won't do it in the future.
I just want to keep this discussion on topic. Is that to much to ask.
Old May 18, 2010 | 05:03 PM
Dr G's Avatar
I too would be interested in this setup, or any other options that Ed would have for 9-bolts.
Old May 25, 2010 | 01:41 PM
FerrMaro's Avatar
Very interested here. Looking for the possibility of rotors with aluminum hats for the rear as well.
Old Jun 2, 2010 | 11:06 AM
87350IROC's Avatar
Car: 87' IROC
I got my stock 9 bolt brakes lookin pretty clean. They look so good I may not even be interested in the Wilwoods anymore.
Just kidding. Still waiting for rear wilwoods for the 9-bolt. Bump for Ed.
Old Jan 10, 2011 | 12:52 PM
87350IROC's Avatar
Car: 87' IROC
Ed,
Friendly reminder.
I see you are working on rear Brembos for the 9-bolt. They almost look similar enough to match my front Wilwoods. Almost. Any word on rear Wilwoods for the 9 bolt?
Old Jan 10, 2011 | 07:08 PM
ebmiller88's Avatar
No problem, now that the rearend is inside I can get to it. I'm running a bit behind on kits, PMs, and e-mail as usual but I'll get to it since the rear is handy now. The brackets I had made for the 9 bolt and C5s need some tweaking at the moment, the Wilwood FSL will be easier.
Thanks for the patience.
Ed
Old Jan 11, 2011 | 12:00 PM
87350IROC's Avatar
Car: 87' IROC
Ed
Excellent. Put me first in line for a set. Do you think the C5 rotors will fit with IROC wheels? I would imagine so, since they are 12" diameter.
Old Jan 11, 2011 | 08:32 PM
ebmiller88's Avatar
Yes, no issue with that one.
Ed
Old Feb 25, 2011 | 12:13 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I'll get in line, here, too.
Old Feb 25, 2011 | 12:28 PM
87350IROC's Avatar
Car: 87' IROC
Excellent.
Old Mar 22, 2011 | 07:32 AM
scholtmj's Avatar
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Ed,
Ad me to the list. Interested in both front and rear kits.
Old Mar 22, 2011 | 05:40 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I am just recieving my parts from Ed now. I ordered the 13" FSLs for the front and LS1s for the back. I wish Ed had offered FSLs for the rear when I ordered these. Just the same, these new brakse will be very nice.
Old May 22, 2011 | 12:17 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
I'm still interested.
Old May 22, 2011 | 04:06 PM
87350IROC's Avatar
Car: 87' IROC
Me too.
Old Sep 25, 2011 | 02:41 AM
87350IROC's Avatar
Car: 87' IROC
Hey Ed. Still here and interested in rear wilwoods for 9 bolt.
Old Sep 25, 2011 | 10:43 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow...this post started in February of 2010....
I've read some posts that Ed does great work, but dang, you guys have some real patience....
Old Sep 25, 2011 | 10:54 AM
87350IROC's Avatar
Car: 87' IROC
It is his option to introduce new products any time he wants. Quite frankly this market is very limited. It is not like we've been waiting for an order to be delivered since then.
If you have another source of big Wilwoods on a 9-bolt, please share.
Old Sep 27, 2011 | 05:19 PM
Confuzed1's Avatar
Car: 83Z28 HO
Let me check into it. I should get back to you in a year or so...
Old Sep 27, 2011 | 05:38 PM
87350IROC's Avatar
Car: 87' IROC
Please stop ruining this productive thread. If you are not interested in Wilwood brakes for a 9 bolt, why are you here?
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TheExaminer
Sep 6, 2015 11:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
Formula_88AE
Sep 3, 2015 01:47 PM
SlowAZ28
Sep 2, 2015 05:19 AM
