Emergency Brake doesnt WORK!@!!!@
Old Mar 20, 2010 | 09:49 AM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
My Emergency Brake on my Automatic 92 Firebird doesnt work, I pull it up so its engaged, the light comes on saying its on, but it doesnt actually ENGAGE MY DAMN BRAKES! I needed them once and I pulled it and nothing happened. WAHT IS WRONGG!?!?! Please Help.
ps From wat i can see, nothing seems to be wrong in the interior. maybe underneath the car??
Old Mar 20, 2010 | 10:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Emergency Brake doesnt WORK!@!!!@
A visual examination is probably the first thing you should do. BTW, if you're a thirdgen freak, I highly suggest purchasing a shop manual for your car. It's one of the best investments you can make.
JamesC
Old Mar 21, 2010 | 03:29 PM
92Firebug's Avatar
Engine: 305 TBI
JamesC
Yeah I was thinking about getting a manual.
Old Mar 21, 2010 | 03:33 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Pull the rear wheels off and have someone watch to see if anything is moving when you pull up on the lever
Could be a broken connection anywhere from lever to brakes
Could be very worn down brakes
Def get a Shop or Haynes Manual...cheap and worth it
Old Mar 21, 2010 | 07:13 PM
92Firebug's Avatar
Engine: 305 TBI
i just bought a haynes manual...itll be here soon, but i think you might be right on the broken connection
Old Mar 25, 2010 | 12:00 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
cables may also be rusted inside their outer sleeve.
Old Mar 31, 2010 | 06:39 PM
RU1NER's Avatar
It could also need adjustment mine does, I pull it straight vertical and it stops the wheels a little but not completely. Just a possibility
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
stalkier
Aug 13, 2015 12:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
