E Brake Help
Old Mar 25, 2010 | 10:01 AM
86stud's Avatar
E Brake Help
I recently bought my camaro and had it converted to a 5 speed. I just found out that one of the previous owners had done a custom disc brake conversion to the rear end and neglected to set up or install the emergency brake, and i need this before i can have the car saftied. I have the hand lever and mechanism in the cab, but I've been told I'm missing everything else. Does anybody know exactly which parts a need to find and what i need to do to fix this issue?
Old Mar 25, 2010 | 10:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: E Brake Help
Originally Posted by 86stud
I just found out that one of the previous owners had done a custom disc brake conversion to the rear end and neglected to set up or install the emergency brake...
Welcome to TGO. I assume you have an 86, which means your car will have the tunnel-mounted adjustment piece. Check the pic in post #4 of the following link:
https://www.thirdgen.org/forums/brak...r-e-brake.html
You don't say what kind of brakes the PO swapped onto the car. If the disc brakes have standard Delco-Moraine calipers (82-88), buy cables for an 86. If the calipers are PBR's (89-97), purchase the first-design mentioned in post #2 of the above link. If LS1 PBR's (98+), you'll need custom cables, such as the ones from the following site:
http://www.flynbye.com/catalog/i153.html
JamesC
Old Apr 29, 2010 | 12:08 AM
86stud's Avatar
Re: E Brake Help
Sorry for the late reply, i just brought the car out. The 86 was actually my last car, this one's an 84, any difference? I'm not sure which were swapped on, i would think the standard ones. I'm going to take a look tomorrow, I'm assuming it will be relatively easy to tell which they are. Also from the way it sounded from the last guy to take a look at my car there was something missing from the brakes. Is there any reason why i would need something more then just the proper cables to make this work?
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
