disk/drum to disk/disk
Old Apr 5, 2010 | 07:07 PM
billy050302's Avatar
I just swapped the rear end out of my 84 z28 from disk/drums to a rear end that has disk/disk. I am not happy with the braking performance. I purchased the right proportioning valve for a disk/disk setup, but is there anything else that needs to be replaced. I have not yet installed the prop valve, I want to make sure I get everything before I start.
Old Apr 5, 2010 | 09:19 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: disk/drum to disk/disk
You'll have to change the brake lines on the axle itself. The drums have a single flex line going from the body to the axle then hard line going into both drums. The calipers need flex line going into them as well.
Old Apr 6, 2010 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Make sure that the combination valve you purchased 'looks' exactly like the one in your car--if not, you may have an SAE vs. metric problem where the lines are concerned. I assume the new rear is an 82-88 with Delco-Moraine iron calipers. If it's an 89+ with PBR's, you'll need the 1LE combination valve. Either way, you'll need parking brake cables, and if the new rear has a different gear ratio, you'll need to swap the drive and/or driven gears to make the speedo function correctly.
The following link, toward the bottom, may answer your questions more fully:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 6, 2010 | 07:58 AM
Thanks for the link. I wasn't sure if I needed a new master cylinder as well, but the link answered it. I guess it wouldn't hurt to change out a 25+ year old master cylinder anyways.
Old Apr 13, 2010 | 11:14 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
i thought i heard somewhere the master cylinder needed to be swapped. is this true?
so far i got:
brake lines
ebrake cables
prop valve
(i plan on keeping the same gear ratio)
Old Apr 14, 2010 | 06:12 AM
JamesC's Avatar
No. The following from the 10-Bolt FAQ I listed above:
If I Swap From a Drum to a Disc Rear End Do I Have to Change the Master Cylinder?
No. https://www.thirdgen.org/forums/brak...fferences.html (Master Cylinder Differences)
JamesC
Old May 13, 2010 | 05:19 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
he would be right on an older camaro but these ones i believe you just have to change the porportioning valve to make it work, i got mine out of a car and grabbed everything i could but the portportionging valve
srthompson1980
Brakes
Sep 2, 2015 03:33 PM
KiLLJ0Y
Brakes
Sep 9, 2014 06:49 PM
patricklav
May 30, 2012 12:11 PM
racing geek
32
Jul 20, 2010 12:56 PM
drperformance
Brakes
Dec 2, 2009 03:33 PM
