Backing plates WTF !!??
Old Apr 9, 2010 | 05:36 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I'm need to get my rearend to the speed shop to get rebuilt. Is it possible to just remove the backing plates and brakes as a whole assembley? I unbolted the 2 small screws on the bottom and removed the one large nut on the top back for the axle flange but the backing plate dosent seem like it wants to budge. Is there sometihng else i need to un bolt or just yank on the backing plate more ?
Old Apr 9, 2010 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Backing plates WTF !!??
you have drums i assume? the axles have to come out to get the plates off, after that, everything should come off as one piece.
Old Apr 9, 2010 | 06:33 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Yes I have drums. Axles are out, everthing is in bolted. Just seems like it dosent want to budge and I didnt want to force it.
Old Apr 9, 2010 | 07:18 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes you dont have to dissasemble the brakes to remove the entire plate and brakes assembly. ive done it many times even on an 84 z28 when i swapped on 1980 cutlass ones
if you removed all four bolts then the plates should come off
maybe they are just stuck good
knock them around a bit with a BFH
Old Apr 9, 2010 | 07:48 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Are you sure theres 4 bolts i onyl see 3 ?
Old Apr 9, 2010 | 07:57 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
should only be three, one big one on top, and two smaller on the bottom if memory serves
Old Apr 9, 2010 | 08:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yeah, drums have 3 bolts. Smack the thing with a BFH, its just stuck/rusted on
Old Apr 11, 2010 | 05:19 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
3 or 4 or whatever yeah, just remove them. some dont have 4. some do. most of the older stuff does anyways.
i work on everything and its 90% of the time 4 of them
but.,,,,, lol
good luck
Old Apr 11, 2010 | 06:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
but.,,,,, lol
Hey, Randy,
If there are four-bolt flanges on a drum rear (another member has suggested that that's the case), would the rear disc backing plate bolt up?
JamesC
Fronzizzle
Mar 18, 2019 08:29 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
