Vacauum line or Brake Booster?
Car: 92 formula w/t-tops
Engine: 350 (L98) 5.7 TPI
Transmission: 700-R4
I just noticed a hissing sound coming from my brake pedal when I press it down. It doesn't do it unless I press on it. I turned my car off to see what it would do and where as I usually can press it about 2-3X before it becomes hard, I only had to press it down just a bit 1X and it hissed and the pedal became hard.
Vacuum leak or brake booster?
Thanks for any replies.
Re: Vacauum line or Brake Booster?
It's never does this sound before or acted like this. I mean yes, it makes a sound when depressing the pedal, but never when just holding it a certain position. Like when you have to press the pedal 2-3X when the car is off to get the pedal rock hard. I only have to press it an inch and it "leaks" all the vacuum out and becomes hard in seconds.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it shouldnt all bleed out in one press, maybe you did blow something in the booster
